Mince Interpreter for the Propeller -- Forth wins - Page 2 — Parallax Forums
2
    edited 2014-02-07 22:34
    jazzed wrote: »
    That's the way it is in the USA at least.
    It's also how little kids learn math - please don't confuse them.
    I can see the campaign now, "Just say No to Forth! Do it for the children." :lol:
  • jmgjmg Posts: 15,194
    edited 2014-02-07 23:14
    David Betz wrote: »
    Here are the Fibo results for ebasic3/mince running on a C3:
    Good info.
    How does that compare with other Interpreter choices ?
  • koehlerkoehler Posts: 598
    edited 2014-02-07 23:31
    David Betz wrote: »
    Yes, that's me.
    What would that be?
    No need for any apologies. :-)
    Well, thats cool.
    Just got an old copy of LIPS: A gentle introduction to symbolic computation by Touretzky. In my searching, I came across an old link that mentioned a David Betz as creating XLisp. Now I don't have to ask.
    edited 2014-02-08 01:05
    mindrobots,
    Maybe because infix is more similar to many natural languages:
    The emphasis here is on the "many". I don't believe infix or post fix is hard wired into the human brain. Any more than writing from left to right or top to bottom.
    An example. In Finnish "The cat is on the table." is "Kissa on p
    edited 2014-02-08 03:14
    jmg wrote: »
    Good info.
    Steve (jazzed) gave me these numbers for PropGCC:
    propgcc lmm:
    fibo(26) = 121393 (00927ms) (74224848 ticks)
    propgcc cmm (no fcache):
    fibo(26) = 121393 (04792ms) (383407984 ticks)
    I searched the forums and found this number for Spin for fibo(8):
    Spin 137360 25
    The ebasic3/mince number for fibo(8) is:
    fibo(8) = 21 (1ms) (112512 ticks)
    That makes ebasic3/mince a little faster than Spin for this benchmark. However, don't take that too seriously since I didn't run the test myself and there might have been a difference in the methodology.
    edited 2014-02-08 03:17
    Heater. wrote: »
    Another example is JavaScript. A language that is far removed from C in it's semantics and a lot more expressive language. But it was demanded that Brendan Eich make it look like C with all the squiggly brackets, the same operators and so on. JavaScript is a lot more like Lisp or Self than C but it was felt those syntaxes would not be popular.
    I llike Lisp syntax. It is very regular and it's easy to construct programatically. The zillions of parens don't bother me at all. However, I know I'm in a small minority.
    edited 2014-02-08 04:09
    Finally got back to try out the fibo benchmark and these are the results:
    [FONT=courier new]: fibo ( n -- f )
      0 1 ROT 0 OVER IF DO OVER + SWAP LOOP ELSE 2DROP THEN DROP
      ;  ok
         ok
    DECIMAL  ok
    0 27 ADO CR ." fibo(" I . ." ) = " NEWCNT I fibo  .LAP ."  result =" . LOOP
    fibo(0) = 13us result =0
    fibo(1) = 19us result =1
    fibo(2) = 22us result =1
    fibo(3) = 26us result =2
    fibo(4) = 29us result =3
    fibo(5) = 32us result =5
    fibo(6) = 35us result =8
    fibo(7) = 38us result =13
    fibo(8) = 42us result =21
    fibo(9) = 45us result =34
    fibo(10) = 48us result =55
    fibo(11) = 51us result =89
    fibo(12) = 54us result =144
    fibo(13) = 58us result =233
    fibo(14) = 61us result =377
    fibo(15) = 64us result =610
    fibo(16) = 67us result =987
    fibo(17) = 70us result =1597
    fibo(18) = 74us result =2584
    fibo(19) = 77us result =4181
    fibo(20) = 80us result =6765
    fibo(21) = 83us result =10946
    fibo(22) = 86us result =17711
    fibo(23) = 90us result =28657
    fibo(24) = 93us result =46368
    fibo(25) = 96us result =75025
    fibo(26) = 99us result =121393 ok
    [/FONT]
    edited 2014-02-08 04:13
      ;  ok
         ok
    DECIMAL  ok
    [/FONT]
    Wow! That's impressive. I'm not sure I understand how it works though. Is it a recursive algorithm? I don't see a call to fibo in its body? Or is that what DO does?
    edited 2014-02-08 04:39
    Okay, I have a question. Which of these is easier to understand?
    Iterative Forth:
    \ fibonacci - iterative method - but skip test for n = 0
    : fibo ( n -- f )
      0 1                           \ Setup initial calculations "0 1"
      ROT                           \ rotate n to top of stack - for n times
      FOR
        OVER + SWAP                 \ next iteration -> result prev
      NEXT
      DROP                          \ discard the prev result, leave the current result
    Recursive Forth:
    : fibo ( n -- result ) dup 2 >= if dup 1- fibo swap 2- fibo + then ;
    C:
    unsigned int fibo (unsigned int n)
        if (n < 2)
            return (n);
        else
            return fibo(n - 1) + fibo(n - 2);
    ebasic3:
    def fibo(n)
      if n < 2 then
        return n
      else
      end if
    end def
    I readily admit that the last two are more familiar to me because I know those languages. Does a Forth programmer find the first example as easy to follow as the other two?
    edited 2014-02-08 05:17
    Okay, that was a quick and dirty one liner, not meant for reading, just doing. Here is a slight refinement and it runs faster again.
    [FONT=courier new]\ fibonacci - iterative method - but skip test for n = 0
    : fibo ( n -- f )
      FOR
      NEXT
    \ fibonacci test - just a Q&D one liner
    DECIMAL
    1 26 ADO CR ." fibo(" I . ." ) = " NEWCNT I fibo  .LAP ."  result =" . LOOP
    fibo(1) = 13us result =1
    fibo(2) = 16us result =1
    fibo(3) = 19us result =2
    fibo(4) = 22us result =3
    fibo(5) = 25us result =5
    fibo(6) = 28us result =8
    fibo(7) = 31us result =13
    fibo(8) = 34us result =21
    fibo(9) = 37us result =34
    fibo(10) = 40us result =55
    fibo(11) = 43us result =89
    fibo(12) = 46us result =144
    fibo(13) = 49us result =233
    fibo(14) = 52us result =377
    fibo(15) = 55us result =610
    fibo(16) = 58us result =987
    fibo(17) = 61us result =1597
    fibo(18) = 64us result =2584
    fibo(19) = 67us result =4181
    fibo(20) = 70us result =6765
    fibo(21) = 73us result =10946
    fibo(22) = 76us result =17711
    fibo(23) = 79us result =28657
    fibo(24) = 82us result =46368
    fibo(25) = 85us result =75025
    fibo(26) = 88us result =121393 ok
    [/FONT]
    edited 2014-02-08 05:21
    It would be interesting to ask that question of people who have never programmed or even seen a program before.
    Clearly option 3 would be the winner. Assuming they speak English and know a little mathematics they could probably just read that like they would other instructions in English.
    The Forth is of course gibberish.
    That Forth line has "LOOP" in it. This makes me suspicious that it is not recursive. Not in the spirit of the benchmark.
    Could someone confirm this?
    edited 2014-02-08 05:23
    Peter,
    That looks better.
    Can we have the proper recursive version?
    For me the C and the Mince versions are easier to understand. The Forth example requires following values on the stack, which makes it less obvious. However, I think an experienced Forth programmer could follow the Forth example as easily as the other two.
    edited 2014-02-08 05:48
    Dave Hein wrote: »
    That's what I was wondering. I know APL programmers used to be able to understand one-liners that I found totally opaque. The Forth version is certainly more concise than either of the other two and seems to be faster although I think it's an interative algorithm. I'll bet the recursive one will still be faster though.
    edited 2014-02-08 06:03
    Under pfth the recursive version looks like this:
    However, in ANS Forth a word calls itself using the RECURSE word. That's because fibo is not supposed to be in the dictionary until the ";" is encountered. pfth currently adds a compiled word to the dictionary when processing the ":" word. I'll fix that someday.
    edited 2014-02-08 06:54
    Mince is interesting too bad it is too large. Given that ZiCog exists, shouldn't it be possible to port a Z80 interpreted language to the Propeller? There were some pretty compact interpreters on the Z80 which should allow for comparison of a hub executed language to Forth.
    edited 2014-02-08 06:56
    Martin_H wrote: »
    Actually, it does fit in hub memory using PropGCC's CMM memory mode if you leave out the filesystem code. That is rather large in PropGCC.
    Does ZiCog run CP/M without requiring any external memory?
    edited 2014-02-08 06:59
    Dave Hein wrote: »
    Thanks Dave. Any chance you could run fibo(26) and report the elapsed time?
    edited 2014-02-08 07:13
    David Betz wrote: »
    I don't know. I was thinking that you would leave out file system and just run the binary from hub ram. But it sounds Mince does that already.
    edited 2014-02-08 07:17
    Martin_H wrote: »
    Yes, it can. I could probably add LOAD and SAVE commands to save programs to high EEPROM and still fit in hub memory although I haven't done that yet. I could also implement a block filesystem like some Forths do. I'm not sure if that's the way Tachyon or pfth do that though.
    edited 2014-02-08 07:19
    David,
    Back in the day when we only emulated the 8080 (PropAltair) it was possible to have 24K of HUB free for 8080 code.
    It would run MS 4K and 8K BASIC for example.
    CP/M will run in that but it's hardly useful. Not enough to run the BDS C compiler for example.
    Latest builds had a FAT file system thrown which ate all the HUB forcing all Z80 space out to external RAM.
    edited 2014-02-08 07:28
    Heater. wrote: »
    David,
    Thanks for the info. I guess it would be hard to write a recursive fibo function in MS 4K or 8K Basic but it seems like 24K of hub memory would be enough to run some more capable languages. I'm pretty sure that an early verison of xlisp ran in 32k of memory under CP/M. It certainly ran in slightly less than that on a PDP-11.
    Edit: No, I'm wrong about the PDP-11. Mine had 60K of RAM.
    edited 2014-02-08 08:11
    Of course running an emulator to run an interpreter is going to be awful slow. It's kind of a clunky way to go anyway.
    I found APL more comprehensible than Prolog.
    That is sad, given that I littered what APL I wrote with lamps.
    David Betz wrote: »
  • jazzedjazzed Posts: 11,803
    edited 2014-02-08 09:00
    Iterative fibo dance interpretation using PropellerGCC LMM.
     * This is the main fiboiterative program file.
     * Fibonnaci numbers skipping fibo(0).
     * Uses iterative (default) or recursive method.
     * Saves results and times in an array, then prints them.
    #include <stdio.h>
    #include <unistd.h>
    #include <propeller.h>
    #define LAST 26
    inline int fiboi(int num)
      int fibo  = 1;
      int fibo1 = 1;
      int fibo2 = 1;
      int j;
      if(num < 3) {
        return fibo;
      else {
        fibo1 = 1;
        fibo2 = 1;
        for(j = 3; j <= num; j++) {
          fibo  = fibo1 + fibo2;
          fibo2 = fibo1;
          fibo1 = fibo;
      return fibo;
    int fibor(int num)
      if (num < 3) {
        return 1;
      return fibor(num-1) + fibor(num-2);
    int main(void)
        int n;
        int times[LAST+1];
        int result[LAST+1];
        sleep(1); // startup time for SimpleIDE
        for(n = 1; n <= LAST; n++) {
            times[n]    = CNT;
            result[n]   = fiboi(n); // replace with fibor(n) for recursive function
            times[n]    = CNT-times[n];
        if(times[LAST]*125/10000 < 100) {
                printf("fibo(%2d) = %6d (%4d ticks) (%dus)\n", n, result[n], times[n], times[n]*125/10000);
        else {
                printf("fibo(%2d) = %6d (%8d ticks) (%dms)\n", n, result[n], times[n], times[n]*125/10000000);
        return 0;
    fibo( 1) =      1 (  24 ticks) (0us)
    fibo( 2) =      1 (  20 ticks) (0us)
    fibo( 3) =      2 (  68 ticks) (0us)
    fibo( 4) =      3 (  84 ticks) (1us)
    fibo( 5) =      5 ( 116 ticks) (1us)
    fibo( 6) =      8 ( 148 ticks) (1us)
    fibo( 7) =     13 ( 180 ticks) (2us)
    fibo( 8) =     21 ( 196 ticks) (2us)
    fibo( 9) =     34 ( 228 ticks) (2us)
    fibo(10) =     55 ( 260 ticks) (3us)
    fibo(11) =     89 ( 292 ticks) (3us)
    fibo(12) =    144 ( 308 ticks) (3us)
    fibo(13) =    233 ( 340 ticks) (4us)
    fibo(14) =    377 ( 372 ticks) (4us)
    fibo(15) =    610 ( 404 ticks) (5us)
    fibo(16) =    987 ( 420 ticks) (5us)
    fibo(17) =   1597 ( 452 ticks) (5us)
    fibo(18) =   2584 ( 484 ticks) (6us)
    fibo(19) =   4181 ( 516 ticks) (6us)
    fibo(20) =   6765 ( 532 ticks) (6us)
    fibo(21) =  10946 ( 564 ticks) (7us)
    fibo(22) =  17711 ( 596 ticks) (7us)
    fibo(23) =  28657 ( 628 ticks) (7us)
    fibo(24) =  46368 ( 644 ticks) (8us)
    fibo(25) =  75025 ( 676 ticks) (8us)
    fibo(26) = 121393 ( 708 ticks) (8us)
    edited 2014-02-08 09:26
    Thanks for the iterative C version! Here is the equivalent in ebasic3:
    def fiboi(n)
      dim fibo, fibo1, fibo2, j
      fibo  = 1
      if n >= 3 then
        fibo1 = 1
        fibo2 = 1
        for j = 3 to n
          fibo2 = fibo1
          fibo1 = fibo
        next j
      end if
      return fibo
    end def
    And the results:
    fiboi(1) = 1 (38us) (3040 ticks)
    fiboi(2) = 1 (38us) (3040 ticks)
    fiboi(3) = 2 (85us) (6864 ticks)
    fiboi(4) = 3 (116us) (9328 ticks)
    fiboi(5) = 5 (147us) (11792 ticks)
    fiboi(6) = 8 (178us) (14256 ticks)
    fiboi(7) = 13 (209us) (16720 ticks)
    fiboi(8) = 21 (239us) (19184 ticks)
    fiboi(9) = 34 (270us) (21648 ticks)
    fiboi(10) = 55 (301us) (24112 ticks)
    fiboi(11) = 89 (332us) (26576 ticks)
    fiboi(12) = 144 (363us) (29040 ticks)
    fiboi(13) = 233 (393us) (31504 ticks)
    fiboi(14) = 377 (424us) (33968 ticks)
    fiboi(15) = 610 (455us) (36432 ticks)
    fiboi(16) = 987 (486us) (38896 ticks)
    fiboi(17) = 1597 (517us) (41360 ticks)
    fiboi(18) = 2584 (547us) (43824 ticks)
    fiboi(19) = 4181 (578us) (46288 ticks)
    fiboi(20) = 6765 (609us) (48752 ticks)
    fiboi(21) = 10946 (640us) (51216 ticks)
    fiboi(22) = 17711 (671us) (53680 ticks)
    fiboi(23) = 28657 (701us) (56144 ticks)
    fiboi(24) = 46368 (732us) (58608 ticks)
    fiboi(25) = 75025 (763us) (61072 ticks)
    fiboi(26) = 121393 (794us) (63536 ticks)
    Not nearly as good as Tachyon.
    edited 2014-02-08 13:37
    David Betz wrote: »
    Under pfth the recursive fibo(26) is 5.5 seconds, and the iterative fibo(26) is 286 micro-seconds.
    edited 2014-02-08 14:20
    Dave Hein wrote: »
    Nice! Thanks for running the test. As I said in the first post in this thread, Forth certainly seems to have beaten my attempts at creating a small fast infix language.
    edited 2014-02-08 15:06
    Mince isn't bad compared to bash. The iterative fibo(26) takes 13 seconds in spinix bash. It's a little faster running in Cygwin on my PC. fibo(26) takes about one-tenth second. I didn't even consider trying the recursive fibo. :)
    edited 2014-02-08 15:18
    Dave Hein wrote: »
    I don't think Mince is bad. It seems to be about the same speed as Spin. I could speed it up a bit by simplifying its memory access to use direct inline rdlong/wrlong instead of calling a function to fetch each long. I did that because it is the VM from xbasic and xbasic can execute code from external memory through a cache. I also do some validity checking like making sure a bytecode is in range and checking for stack overflows and divide by zero which I could eliminate to gain some speed. It seems unlikely though that I'd be able to achieve Tachyon's or even pfth's performance.
    One thing I thought of doing with Mince either in its Basic or C syntax version is to use it to make a Propeller BasicStamp or CStamp by writing it to the EEPROM on the new Prop Mini module that has a 64k EEPROM. I could use the second 32k as a small filesystem to store programs and would end up with a stamp-like module that is self-hosted. Of course, you could do the same thing with any of the Forths and have a faster system. Some people might like the infix syntax though, especially people coming from the BasicStamp/pbasic world.
