printing a circuit on porcelain
I wondered if there is a way to print a circuit on to a porcelain disk? Has anyone ever heard of this and if so please provide some details. It sounds like it may be fragile but that is kind of what I want, to a certain degree.
Much depends on the complexity of the circuit and which is the better bond.
I suppose there might even be a third way. Print a metallic paste on to the surface and then melt the metal in a kiln to have it directly bond. But while that might be the best, it also might be the most difficult to achieve. After all, the metal may oxidize at such extreme temperatures unless a combination of the right flux and the right atmosphere are used.
Google conductive ink. Silver ink pens have been around a while. There is also conductive paint.
Maybe this? http://www.electroninks.com/shop/
For cheap and at-home, I think I'd probably laminate thin copper over the ceramic using epoxy, apply resist, and etch in the normal manner.
If you do want to try the conductive paint idea, and your circuit is not complex or intricate, one method would be to have your design cut out using a plotter cutter, the kind used to make window lettering. Check around at nearby signmaking shops. Coat that with conducive paint or ink (depending on the level of conductivity you need), stick that to the ceramic, and peel off the excess. I've used a similar technique to make home brew capacitative sensors.
2. After etching, the surface where there's no copper will be hardened epoxy, not porcelain.
https://www.google.com/search?num=50&newwindow=1&q=copper+plating+non-conductive+material&oq=plating+copper+on+non-conductive&gs_l=serp.1.0.0i22i30l2.311001.322297.0.326010.21.21.0.0.0.0.143.1753.17j4.21.0....0...1c.1.34.serp..1.20.1604.c2TdnBHaiVs
Rick
