high speed counter
cwyuzik
Hi,
I wonder if someone here could suggest the best propeller based way to count the number of rotations of a pulley running at aprox 600 rpm. The application I'm needing this for is for a motor control for a peristaltic pump. To dispense fluids accurately we need to know exactly how many times the pump pulley has turned.
I've looked at the quadature decoder application here in the obex but it seems like overkill as we don't need to know position or direction of rotation, just the number of revolutions. An un-elegant mechanical limit switch hooked up to an input may work for a while but would soon wear out.
The pulley gear will be 3d printed so any configuration of holes or slots through it is possible.
Clare
Clare
Wow, the luxury of 3D printing
The Prop counters have a Pin-Edge-inc mode, so you can get a clean edge, and use that.
Do you need to know fractions of a revolution ?
As you say, mechanical is the worse choice, but it is simple. (A SPCO microswitch can give a clean edge, with care.)
Next simplest would be a magnet + reed, but that also has life limits.
Then you can go HALL, or Opto, and with your own printing, a slotted interrupter would seem simple.
A schmitt / opto-logic form of opto coupler will give clean edges if well shielded.
Since you have 3D printing, and fractional revs could be useful, you could also look at Single Track Gray Codes.
(http://en.wikipedia.org/wiki/Gray_code#Single-track_Gray_code)
This is a variant on absolute encoding, where one a single track or slot in your case, is needed
- and there are variants which tune for evenly spaced heads, or heads grouped to one half of a circle.
Or with the luxury of 3D printing, you could maybe use dual special tracks, and cluster the sensors more, if that helps assembly.
I see in my notes I found TCST5250, which is a nice deep-groove right angle opto-interrupter. (needs external schmitt)
To clarify this, if you use the Quad mode, in order to get the natural debounce/chatter suppression Phil mentions, you will need 2 sensors and some suitable slot pitch. Usually that would be mechanical strength determined, and likely rounded to 2^n, as you can easily scale down to whole number revolutions ( if whole revs is really what you need).
Alternatively, if there is a scale factor of milliitres/rpm, you could chose any whole number of slots to better fit that value.
Erlend
Using a single phase 1/2hp motor salvaged from an older style automatic washer. The motor comes with a clutch which will soften the initial start up torque so measuring rotations at the motor isn't a viable option.
So looks like the quadrature encoder may be the best solution after all.
Thanks all for your help and suggestions.
Clare
