Suggestions for a bench top power supply and frequency generator?
Hey everyone, Ive been thinking about buying a bench top power supply and possibly a frequency generator and I was wondering what you would recommend in the ~$100 price range. Would it be possible to get one with digital readouts and 2-3 outputs or is that just crazy?
Thanks!
Dave
Thanks!
Dave
A PC power supply can deliver an almost ridiculous amount of current if you short it out. Just about guaranteed to turn your project into a smoking pile of melted wires and plastic if you make a boo-boo.
Physical pots to dial up current limit and voltage - you can power it up in exactly the state
it was in when you last used it.
Coarse and Fine pots for both current and voltage, really really useful.
Analog meters. Nothing else shows you the current and voltage kicks as well, and by
analog I'm not ruling out a LCD bargraph style, so long as its quick to respond to
transients (this is most important for current, but useful for voltage). I'd like
digital meters too of course, but if I need an accurate voltage I get the multimeter out
and measure it at the end of the leads where it matters.
Real analog meters let you see the voltage in the circuit after you switch off the supply!
Great for battery charging.
A current-limit LED with pulse-stretcher so you can see even momentary current limit
events...
Big chunky power switch at the front so you can kill the power QUICK!
Floating outputs with a removable link to connect one of the +ve and -ve terminals
to earth. Then you can use it as +ve or -ve rail supply, or floating.
3A minimum.
Mine's an Instek PS-3030 (I'd like more volts than 30 though).
I think it was put together somewhere in Asia but it serve's my purpose. Especially since I ended up getting it for free via Ebay. Only had to replace a broken pot.
They are flexible in that they can be Master/Slave (for dual tracking operation, or higher current, higher voltage, etc)
It is just as much about where you buy as about what you buy.
Do you already have a scope?
Is it going to be for analog sine wave as well as digital? Are you wanting to go way up into the RF range or do you want an audio generator?
You can pretty well generate a digital signal up to 80 Mhz with the Propeller itself.
I love that site...and yes..they do a great job of ripping the stuff apart.
And there is a lot of truth in that the old stuff is the best stuff...engineering quality into anything cost money...money most companies do not want to spend today.
The downside is that the older equipment is old...and like all of us, age causes things to fail and many times that are no replacements.
Ham fests, swap fests are great places to buy...if you can test it before you buy it.
They are also great places to sell your junk to the next sucker...buyer be very aware.
I have many, many stories of junk being pushed at ham fests.
One can use Ebay's location feature to look for nearby sellers of test electronics....there by avoiding shipping and be able to test before commiting the cash.
Dave
