Reflow oven - temp sensing question
Just curious - is a thermocouple the only valid method for sensing the temp inside the oven? Or is there another preferred method that doesn't require special "K" wires and wire lengths? I just want to keep it simple, something I can control with a stamp, and that I can reasonably make conform to the "recommended" reflow soldering curves.
With the ever increasing load of chips I am finding that I need that are no longer made in through-hole packages... I have to make this transition. I've been teetering on the edge of it for a few years now... gotta do it.
Thanks for the info.
http://www.amazon.com/TekPower-TP4000ZC-RS232-Interaced-Ranging-Multimeter/dp/B000OPDFLM
Thermocouple is the easy route, with respect to temperature range. I am doing the same as you, just with a prop. Look up Maxim's MAX31855, it is simple 3-wire hookup, and only 3 output values.
14-bit thermocouple value 0.25C per bit.
12-bit cold end (internal temp) value 0.0625C per bit
3-bit error value. OPEN, SHORT TO GND, SHORT TO VCC
You can find them ready to go for under $20USD, and thermocouple probes (not wire) for under $5USD.
I've considered making a controller, but for a few reasons decided not to. The above formula works, and it's easy. I can spend 20-30 hours making a proper controller and testing it, or I can do other things. I don't think a controller will save me 20-30 hours of reflow monitoring, so I do other things instead. That's my value equation...
ps: Don't you just love it when "Tech Specs" for a product don't include such basic information as size and weight? Or outlet voltage and frequency? Or output range? The Breville oven web page is pretty much useless.
SLRM - normally I'd agree about time spent in making vs. time saved - but this is just a project I want to make
Thanks folks!
I'm in the process of making my own Parallax reflow oven as well, so it is great to see these recent posts about them.
I too have found that the MAX31855 is easy and affordable and seems to work well. I use Jonny Mac's object for it.
My current situation is I have everything up and running, but the specific reflow temp profile PID algorithm is giving me trouble. I have tons of overshoot on the temperature.
Have either completed your project? If so, can you post your code for the temp profile please?
Thanks!
