AP-16+ schematic
Hello:
The schematic for the AP-16+ board is not in the user guild and i don't see it on it's web page.
Any one know were i could get the schematic? I don't like buying stuff without a schematic.
rich
rich
I designed it (with my partner, John Barrowman, at EFX-TEK), so I can sort out any questions you have that go above-and-beyond the basic documentation. We have full support section for it on the EFX-TEK forums.
Is it Class-D?
How much filtering is there?
Does use a single chip amplifier like a LM3886?
What would be the THD+N at 1W,5W,10W,20W output powers?
But is your clock source to keep the 44.1KHz output rate stable?
Can you do 48KHz audio samples?
Just want to know about the audio circuit quality.
Rich
Filtering? (probably pertains to Class D question)
Each channel uses one TDA7240A (rated for 20W with 18V power supply and 4-ohm load)
See TDA7240A docs for THD specs
We use a 6.25MHz crystal with 16x PLL for system clock of 100MHz
The present software limits to 44.1kHz, but I have tested an update that will play 48kHz files
On the sample rate issue: The design uses an RC DAC with a roll-off of about 17kHz so there is no advantage using 48kHz files. In fact, they just create problems because of the serial access of the SD card; the larger the sample rate, the bigger the file, and some SD cards have trouble keeping up. We recommend re-sampling files to 32kHz; this minimizes the file size without affecting the apparent fidelity of the file.
Please keep in mind that the AP-16+ is a low-cost, consumer/industrial-grade product. If you're looking for high-fidelity, 48kHz playback it will cost you far more than $130.
That cover what i wanted to know.
cheers,
rich
