Ch 8 IR Distance Range
I am going through the Robotics with Boe-Bot book to prepare for teaching a class at our homeschool co-op. My knowledge of electronics is very limited and very rusty. My EE college classes seem so long ago....
I am getting ranges from 13" to 20" for zones 0 to 5 on the left IR LED, and 11" to 36" on the right IR LED. From the text in the book, it seems that these distances are too great. Is this a problem? What about the large discrepancy between left and right?
I am using a 1k resistor.
Thanks for your help,
Diane
Diane
The "distance" isn't really "distance" but brightness. So a white item which reflects IR well will appear closer than a dark item (if I'm remember the sensors correctly).
You can always adjust the distance readings with software if they are causing a problem with navigation.
That said, it would still be interesting to find out which part is the culprit. Here are some things you could try if you'd like to narrow down the search:
First try swapping left and right resistors, then left and right IR LEDs, then left and right receivers. Make sure to cut power during each swap, and re-test between each swap. That can help narrow down whether one of the resistors is smaller than the other, if one of the LEDs happens to be brighter, or if one of the sensors is more sensitive.
If the same side is still more sensitive after all the swaps, try running VDD and VSS (GND) wires directly to each IR detector power input. In other words, instead of having the right IR detector powered in series after the left, make sure they are both getting parallel power with wires directly to VDD and VSS. This will help equalize any effect switching noise might have on the detectors through their power inputs.
The other cause if the sensitivity did not follow any part would be that one I/O pin driving one IR LED has more output resistance than the other for some reason. Testing this would involve disconnecting the resistor to the IR LED and connecting an 220 ohm resistor between that I/O and VSS, and then sending a high signal and measuring the I/O pin voltage. A 220 ohm resistor should pull the I/O pin's high output voltage down measurably. If the voltage is lower on the I/O pin that's driving a more nearsighted circuit, that could explain it.
Check out www.BoeBotTeacher.com for some videos that might help your students with understanding turns and the corner-escape problem.
Getting a kit of assorted resistors gives you some finer adjusting of Ir in hardware. They are also useful for students that want some more experiments with RCTIME. Sample: http://www.amazon.com/Metal-Film-Resistor-Assorted-112ValuesX10pcs/dp/B006CEY8F6 Or I am glad to send you a few each of 20 kinds.
I find the line-following activity difficult because of physical location of sensors. I only use if extra time. However, I am designing a paper template that folds and fits on the front like a bumper and has holes to mount the sensors right down near the paper. I was stuck on a cheap, easy, solder-less way to connect leads back up to breadboard. Now P'lax has item of jumpers so easy to get http://www.parallax.com/product/800-00048
