polulu ir beacon level shift
Polulu ir beacon
Quickstart bd
Bs170
Nte3220
Voltage divider
Has anyone sucessfully level shifted beacon to 3.3 v?
Tried three methods so far getting strange results.
Quickstart bd
Bs170
Nte3220
Voltage divider
I'm pretty sure the answer to this is yes.
Assuming the Pololu beacon outputs 5V (a link would be nice), then all you should need is a 10K (or 3.3K ior 4.7K) resistor to keep the current on the input pin below 500uA.
http://www.pololu.com/product/701
5.6k over 10k gives me 3.2 volts at 320 ua.
I metered it also. However when i put the output into the propeller, it lights up each of the ir leds to which they are attached.
When i increase to 56k over 100k they no longer light up but they stop working.
Too little current maybe?
And again i thank u.
Why 3.3K? It's the nearest standard value to 2.8K which is the calculated minimum one should use to protect the Propeller pins from a 5v signal. Easy to remember, too: 3.3v Propeller uses 3.3K resistor to protect inputs from TTL circuits.
