Activity-Bot + Boe-Bot Tank Tread Kit
I recently purchased the Activity-Bot kit and decided it needed a little help traversing rougher terrain. The Boe-Bot Tank Tread Kit (http://parallax.com/product/28106), seemed like what I needed. The Activity-Bot kit is supposed to be able to accept Boe-Bot add-ons and accessories, however, I was having some trouble getting the tank treads to work with the Activity-Bot.
The encoders and stock wheels need to be removed so the tank tread kit can be attached to the chassis. The high-speed servos do not perform correctly without the encoders. The encoders also need the stock wheels to function.
Has anyone else encountered this problem? I suppose I could use some setup with basic servos, but I really like the control the Activity-Bot's high-speed servos/encoders provide. Any advice would be appreciated.
Thanks!
Thanks!
/* Forward 1 second.c */ #include "simpletools.h" #include "abdrive.h" main { drive_speed(0, 0); drive_feedback(0); drive_speed(128, 128); pause(1000); drive_speed(0, 0); }Note: The ActivityBot calibration is different from the Boe-Bot calibration. It's all code driven and does not require you to manually center the servos with a screwdriver. It instead finds the center, and also builds a linear interpolation table that relates servo signals to actual measured speeds.
If you never have and never will use wheels and encoders, it's probably best to start with the Boe-Bot style calibration. For that, you'll run center code and adjust the pot in each servo with a screwdriver so that it stays still:
/* Center.c */ #include "simpletools.h" #include "servo.h" int main() { servo_speed(12, 0); // Stay still servo_speed(13, 0); }When that's done, your navigation code might look like this. Note that servo_speed has to be the reverse direction for the right (P13) wheel to result in forward motion.
/* Forward 1 second with servo lib.c */ #include "simpletools.h" #include "servo.h" int main() { servo_speed(12, 100); // Forward servo_speed(13, -100); pause(1000); servo_speed(12, 0); // Stop servo_speed(13, 0); }I suggest you dare Duane Degn to do it, 'cuz DD clearly has the fours D's (drive, desire, dedication and discipline) to jump onto a project and run with it. Just look what he did here: http://forums.parallax.com/showthread.php/151868-Cheap-8x8-LED-Displays
