VS1053 + mSD to run mp3 on its own
Erlend
To avoid creating all the sounds I need in .wav I had the idea to run mp3 files from a separate board, as instructed through SPI from Prop. Found a nice break-out board at Ada, but maybe I was too fast (again) to add-to-basket, because now I seem to understand that Prop has to do the work of reading SD and feeding into the VS1053 chip. So instead of occasionally shooting off a short 'play file_nnn' SPI command, now a cog is needed to read&write sound data all the time while playing. Will be hard on prop i/o, and will mean a lot of coding to do for me - I already suffer an inbox-overload situation in my life/brain/lab, so this 'household' coding is not something I urge for now.
I searched Obex, but with little luck, so now I ask the Forum for help - maybe someone have already intefaced this breakout board, or at least the VS1053 chip - or maybe there is an other board out there which is doing exactly what I wanted? Or maybe I am wrong about the ada-board - that it can do this after all?
Erlend
Erlend
A better choice for what you're trying to do would be the Daisy player kit, which includes a PIC uC to read the card and simple inputs to trigger playback:
http://www.teuthis.com/daisy/
Or, a bit fancier, smaller, more capable, and pre-assembled, Rogue Robotics uMP3:
http://www.roguerobotics.com/products/electronics/ump3
If you'd like to see an example of a Propeller controlling a similar codec, Harrison Pham's award-winning Thumper does this as well as a lot of other cool network streaming stuff:
http://classic.parallax.com/Thumper/tabid/848/Default.aspx
I will put the ada-player in a drawer for some future project. Both the uMP3 and the Vmusic2 fit my purpose perfectly, but I think I will go for the Vmusic because - I did not think about that before - the USB stick is a more convenient format in this application. The interface looks dead simple, with SPI or serial, and a easy command set.
Erlend
PUB Speak(n) case n 0 : ser.str(2, string("VPF 0.mp3", CR)) waitcnt(40_000_000 + cnt) 1 : ser.str(2, string("VPF 1.mp3", CR)) waitcnt(40_000_000 + cnt) 2 : ser.str(2, string("VPF 2.mp3", CR)) waitcnt(40_000_000 + cnt) PUB SayNumber(num) | x, y, z 'will not say '0' ??? Silence VolUP x := (num/100) * 100 y := ((num/10) // 10) * 10 z := num // 10 If (y+z) > 9 AND (y+z) < 20 z := y + z y~ if x > 0 Silence VolUp speak(x) waitcnt(40_000_000 + cnt) if y > 0 Silence VolUp speak(y) waitcnt(40_000_000 + cnt) if z == 0 if x == 0 AND y == 0 Silence VolUp speak(z) if z > 0 Silence VolUp speak(z) PUB SetVol ser.str(2, string("VSV")) ser.tx(2, $20) ser.tx(2, VoiceVol) ser.tx(2, $0D) PUB Set1033Rate ser.str(2, string("VWR")) ser.tx(2, $20) ser.tx(2, $05) 'sample rate ser.tx(2, 44101) ser.tx(2, 44101 >> 7) ser.tx(2, $0D) PUB Set1033Mode ''unused should be vwr? ser.str(2, string("VRD")) '''v read ser.tx(2, $20) ser.tx(2, Mode) '''MODE=$00, VOL=$0B, STATUS=$01, audata/RATE=$05, BASS=$02 ser.tx(2, Mode >> 8) ser.tx(2, CR) PUB Set1033Bass ser.str(2, string("VWR")) ser.tx(2, $20) ser.tx(2, $02) 'bass ser.tx(2, 1111_1111) ' bass15 14 13 12 booost 1-15 .. freq ser.tx(2, 0001_0001) 'trebel 7654 boost/cut -8..7 0 = off ... freq ser.tx(2, $0D) PUB VolON ser.str(2, string("VSV")) ser.tx(2, $20) ser.tx(2, 00) ser.tx(2, $0D) PUB VolOFF ser.str(2, string("VSV")) ser.tx(2, $20) ser.tx(2, 100) ser.tx(2, $0D) PUB ReadFile(readlen) 'rd4 := readlen >> 24 'rd3 := readlen >> 16 'rd2 := readlen >> 8 'rd1 := readlen 'ser.str(2, string("RDF")) 'ser.tx(2,$20) 'ser.tx(2,rd4) 'ser.tx(2,rd3) 'ser.tx(2,rd2) 'ser.tx(2,rd1) 'ser.tx(2,$0D) PUB OpenFile(filename) 'ser.str(2, string("OPR")) 'ser.tx(2, $20) 'ser.str(2, filename) 'ser.tx(2, $0D) PUB CloseFile(cfname) 'ser.str(2, string("CLF")) 'ser.tx(2, $20) 'ser.str(2, cfname) 'ser.tx(2, $0D) Pub Seek(s) 'seek to a specific location within an already open for read file 'sekval := s 'sekval is long, destination to seek for read start 'go(0,0) 'ser.hex(3, sekval, 4) 'sek4 := sekval >> 24 'sek3 := sekval >> 16 'sek2 := sekval >> 8 'sek1 := sekval 'ser.str(2, string("SEK")) 'ser.tx(2,$20) 'ser.tx(2,sek4) 'ser.tx(2,sek3) 'ser.tx(2,sek2) 'ser.tx(2,sek1) 'ser.tx(2,$0D) PUB OpenFileToWrite(filename) 'open or create file ''''ser.str(2, string("OPW")) 'ser.tx(2, $4F) 'O 'ser.tx(2, $50) 'P 'ser.tx(2, $57) 'W 'ser.tx(2, $20) 'ser.str(2, filename) 'ser.tx(2, $0D) PUB WriteFileSize(size) '4 bytes specifies size of data to follow in WriteData 'wr4 := size >> 24 'wr3 := size >> 16 'wr2 := size >> 8 'wr1 := size 'ser.str(2, string("WRF")) 'ser.tx(2,$20) 'ser.tx(2,wr4) 'ser.tx(2,wr3) 'ser.tx(2,wr2) 'ser.tx(2,wr1) 'ser.tx(2,$0D) PUB WriteData(size, pointer) | g, o 'send the data part of WriteFile 'g~ 'repeat size ''''ser.tx(2, testbyte[g]) 'ser.tx(2, byte[pointer][g]) 'g++ 'ser.tx(2,$0D) PUB readusb(size) | m, v, t, check 't~ 'w(500_000) 'delay required else usb hangs 'm~ 'Repeat until t == size '<<<<<warning flag leave at 64 'v := ser.rxtime(2, 200) ' (z, 100) 'read more, port 0, wait 2 ms if no byte 'If v == -1 'Return -1 'ResponseArray1[m] := v 'm++ 't++ 'if check < 54 'detect/remove previous vinculum response left overs if below first 54 bytes 'if ResponseArray1[m - 3] == $5C 'vinc left over info string 'if ResponseArray1[m - 2] == $3E 'vinc left over info string 'if ResponseArray1[m - 1] == $0D 'vinc left over info string 'm~ 'reset all if old string rec'd 't~ 'reset all if old string rec'd 'check~ 'reset all if old string rec'd ''''''w(100000) 'check++ PUB ReadFileFromUSB(size, startaddr, filename) 'how to set to read if above 64bytes? ''''if size is greater than current file size, device pads FE 'ser.str(3, filename) 'OpenFile(filename) 'if startaddr > -1 'seek(startaddr) 'ReadFile(size) 'read the file at start, using readsize 'readusb(size) 'WritePage(eeprom1, eepromwriteindex, @ResponseArray1, size) 'always store to eeprom1? 'CloseFile(filename) PUB TestUSBReadWRite 'WriteFileToUSB(8, 0,string("logger")) 'waitcnt(40_000_000 + cnt) 'ReadFileFromUSB(8, 0, string("logger")) PUB VStop ser.str(2, string("VST", CR)) ser.tx(2, $0D) PUB VoiceIntro Silence Volup ser.str(2, string("VPF 1005.mp3", CR)) 'Fade PUB VolUp ser.str(2, string("VWR")) ser.tx(2, $20) ser.tx(2, $0B) ser.tx(2, VoiceVol) 'left ser.tx(2, VoiceVol) 'right or vice versa? ser.tx(2, $0D) PUB Reset 'stop playing audio ser.str(2, string("VWR")) ser.tx(2, $20) ser.tx(2, $00) ser.tx(2, ResetMode) ser.tx(2, ResetMode >> 8) 'jump out of wave decode ser.tx(2, $0D) PUB Mute ser.str(2, string("VWR")) ser.tx(2, $20) ser.tx(2, $0B) ser.tx(2, $FE) 'left ser.tx(2, $FE) 'right or vice versa? ser.tx(2, $0D) PUB Silence Mute 'change to fast fade vol off, might be smoother Vstop ResetThanks a bunch for the code!
Erlend
Another SD option:
https://www.sparkfun.com/products/11029
I will buy one! (two, actually).
Erlend
That said, if you're wanting to do much more with any processor you're probably better off getting an all-in-one. The VMusic module is one choice, but there's also others, such as the MP3 Trigger board Sparkfun sells. I've used it and it's painfully easy.
Tim
Erlend
To be clear, both Daisy and Rogue Robotics uMP3 have SD sockets and are entirely self-propelled, needing just a command to start playing a song. The uMP3 has its SD socket on the back of the card to make the card smaller. Daisy can be set up to be even simpler to control, where just a pulse or contact closure will trigger playback of an entire song. While all the tools are there to drive a MP3 codec chip from the Propeller, the SD card filesystem will eat a good chunk of Hub RAM just to get the bits out of the file in order.
