RFID Reader/Writer Spin Issue
I just bought an RFID Reader/Writer on EBay. Great deal since I got it for $36.00 shipped with 2 chips.However, I am unable to get a response from it using the below code on my Propeller BOE Board. I tested it on a BS2 Homework board and Demo code and it worked fine. I am using 5V power from the HW board that is supplied via a wall wart. I also tried to directly plug in to the Prop BOE 5V but I still get nothing. Have tried pretty much all Baud rates although it is suppose to run at 9600. Any help is appreciated.
{{ ┌───────────────────────────────────────────┐ │ RFID RFID Read/Write Object Wrapper │ │ Author: TinkersALot │ │ Adapted from Joe Grand's BS2 code. │ │ See end of file for terms of use. │ └───────────────────────────────────────────┘ Each RFID card function is tested by entering a specific key on the PST as follows: Z = test serial number read of legacy card read S = read new style card serial number C = try to logon to card (follow the prompts to enter 4 DIGITS password) D = read all card data (this one seems a bit flakey to me still) W = write data to card -- not implemented yet in terminal command P = change the card password ( follow the prompts to enter 4 DIGITS for old and new password ) (needs a bit more testing) R = Reset the card U = Unlock the card L = Lock the card }} CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 RFID_TX = 9 ' Connects to RFID R/W Module SIN RFID_RX = 10 ' Connects to RFID R/W Module SOUT obj Host : "FullDuplexSerial" RFID : "RFID.Reader.Writer.Driver" var byte TestBuffer[ 12 ] byte TestDataBuffer[ 32 * 4 ] byte OldPwdBuffer[ 4 ] byte NewPwdBuffer[ 4 ] byte HostDataBuffer[ 10 ] PUB TEST_THIS | ErrCheck, CmdByte, LoopCounter, IndexCounter, Offset {{ Test this driver }} ' start the host interface ( connected to PST ) ' ErrCheck := Host.Start( 29, 28, 0, 19200 ) if 0 == ErrCheck Host.str( string( "Cog Start Error", 13 ) ) else ' since host interface started, the next thing to do is to ' call the driver start method to start its I/O interface ' ErrCheck := RFID.Start( RFID_RX, RFID_TX ) if 0 == ErrCheck Host.str( string( "Cog Start Error", 13 ) ) ' if everything worked above, then enter terminal I/O loop ' if ErrCheck <> 0 Host.str( string( "Ready", 13 ) ) repeat CmdByte := Host.Rx if CmdByte == $5A ' Z = Legacy read Host.str( string( "Reading Legacy tag's unique serial number...", 13 ) ) Result := RFID.TryGetLegacyCardNumber( @TestBuffer, 5 ) if Result <> 0 repeat LoopCounter from 0 to 10 Host.hex( TestBuffer[ LoopCounter ], 2 ) Host.str( string( 13 ) ) Host.str( string( 13 ) ) else Host.str( string( "Failed to read legacy unique serial number...", 13 ) ) if CmdByte == $53 ' S erial number Host.str( string( "Reading tag's unique serial number...", 13 ) ) Result := RFID.TryGetCardSerialNumber( @TestBuffer, 5 ) if Result <> 0 repeat LoopCounter from 0 to 4 Host.hex( TestBuffer[ LoopCounter ], 2 ) Host.str( string( 13 ) ) Host.str( string( 13 ) ) else Host.str( string( "Failed to read unique serial number...", 13 ) ) if CmdByte == $43 ' C ard login Host.str( string( "Trying to logon to card...", 13 ) ) Host.str( string( "Enter 4 digit password", 13 ) ) OldPwdBuffer[ 0 ] := Host.rx - $30 OldPwdBuffer[ 1 ] := Host.rx - $30 OldPwdBuffer[ 2 ] := Host.rx - $30 OldPwdBuffer[ 3 ] := Host.rx - $30 Result := RFID.TryCardLogin( @OldPwdBuffer, 5 ) if Result <> 0 Host.str( string( "Card Logon Succeeded...", 13 ) ) else Host.str( string( "Card Logon Failed...", 13 ) ) if CmdByte == $44 ' D ata Read Host.str( string( "Trying to read all card data...", 13 ) ) bytefill( @TestDataBuffer, 0, 128 ) Result := RFID.TryToReadCardData( @TestDataBuffer, 0, 32, 5 ) if Result <> 0 Host.str( string( "Card Data Read Succeeded...", 13 ) ) Host.str( string( "Card Data Dump Follows...", 13 ) ) Offset := 0 repeat LoopCounter from 1 to 32 if LoopCounter < 10 Host.str( string( " " ) ) Host.dec( LoopCounter ) Host.str( string( " " ) ) repeat IndexCounter from 0 to 3 Host.hex( TestDataBuffer[ Offset ], 2 ) Offset++ if LoopCounter > 2 and LoopCounter < 32 Host.str( string( " [* writeable]" ) ) Host.str( string( 13 ) ) Host.str( string( 13, 13, "End Card Data Dump ", 13 ) ) if CmdByte == $57 ' W rite data Host.str( string( "Trying to write data to card...", 13 ) ) Host.str( string( "Enter address ( 3 to 31 )", 13 ) ) ErrCheck := GetHostDecimal( $0A ) if ErrCheck < 3 or ErrCheck > $1F Host.str( string( "Invalid address ( range is: 3 to 31 )", 13 ) ) else Host.str( string( "Will Write To Address: " ) ) Host.dec( ErrCheck ) Host.str( string( 13 ) ) Host.str( string( "Enter 4 bytes of data ( each byte separated by carriage return)", 13 ) ) OldPwdBuffer[ 0 ] := 0 OldPwdBuffer[ 1 ] := 0 OldPwdBuffer[ 2 ] := 0 OldPwdBuffer[ 3 ] := 0 Result := -1 repeat until Result <> -1 Host.str( string( "Trying To Read Byte 1", 13 ) ) Result := GetHostHex( $0A ) if Result <> -1 OldPwdBuffer[ 0 ] := Result Host.str( string( "Byte 1 is: " ) ) Host.hex( OldPwdBuffer[ 0 ], 2 ) Host.str( string( 13 ) ) Result := -1 repeat until Result <> -1 Host.str( string( "Trying To Read Byte 2", 13 ) ) Result := GetHostHex( $0A ) if Result <> -1 OldPwdBuffer[ 1 ] := Result Host.str( string( "Byte 2 is: " ) ) Host.hex( OldPwdBuffer[ 1 ], 2 ) Host.str( string( 13 ) ) Result := -1 repeat until Result <> -1 Host.str( string( "Trying To Read Byte 3", 13 ) ) Result := GetHostHex( $0A ) if Result <> -1 OldPwdBuffer[ 2 ] := Result Host.str( string( "Byte 3 is: " ) ) Host.hex( OldPwdBuffer[ 2 ], 2 ) Host.str( string( 13 ) ) Result := -1 repeat until Result <> -1 Host.str( string( "Trying To Read Byte 4", 13 ) ) Result := GetHostHex( $0A ) if Result <> -1 OldPwdBuffer[ 3 ] := Result Host.str( string( "Byte 4 is: " ) ) Host.hex( OldPwdBuffer[ 3 ], 2 ) Host.str( string( 13 ) ) Result := RFID.TryToWriteDataToCard( ErrCheck, @OldPwdBuffer, 5 ) if Result <> 0 Host.str( string( "Card Data Write Succeeded...", 13 ) ) else Host.str( string( "Card Data Write Failed...", 13 ) ) if CmdByte == $50 ' P assword set Host.str( string( "Trying to logon to card...", 13 ) ) Host.str( string( "Enter current 4 digit password", 13 ) ) OldPwdBuffer[ 0 ] := Host.rx - $30 OldPwdBuffer[ 1 ] := Host.rx - $30 OldPwdBuffer[ 2 ] := Host.rx - $30 OldPwdBuffer[ 3 ] := Host.rx - $30 Host.str( string( "Enter new 4 digit password", 13 ) ) NewPwdBuffer[ 0 ] := Host.rx - $30 NewPwdBuffer[ 1 ] := Host.rx - $30 NewPwdBuffer[ 2 ] := Host.rx - $30 NewPwdBuffer[ 3 ] := Host.rx - $30 Result := RFID.TrySetCardPassword( @OldPwdBuffer, @NewPwdBuffer, 5 ) if Result <> 0 Host.str( string( "Card Password Change Succeeded...", 13 ) ) else Host.str( string( "Card Password Change Failed...", 13 ) ) if CmdByte == $52 ' R eset card Host.str( string( "Trying to reset card...", 13 ) ) Result := RFID.TryCardReset( 5 ) if Result <> 0 Host.str( string( "Card Reset Succeeded...", 13 ) ) else Host.str( string( "Card Reset Failed...", 13 ) ) if CmdByte == $55 ' U nlock card Host.str( string( "Trying to unlock card...", 13 ) ) Result := RFID.TryCardUnlock( 5 ) if Result <> 0 Host.str( string( "Card unlock Succeeded...", 13 ) ) else Host.str( string( "Card unlock Failed...", 13 ) ) if CmdByte == $4C ' L ock card Host.str( string( "Trying to lock card...", 13 ) ) Result := RFID.TryCardLock( 5 ) if Result <> 0 Host.str( string( "Card lock Succeeded...", 13 ) ) else Host.str( string( "Card lock Failed...", 13 ) ) PUB GetHostDecimal( Delimiter ) : Value | place, ptr, x {{ Accepts and returns serial decimal values, such as "1234" as a number. String must end in a carriage return (ASCII 13) x:= Serial.rxDec ' accept string of digits for value }} place := 1 ptr := 0 value := 0 HostDataBuffer[ ptr ] := Host.rx ptr++ repeat while ( HostDataBuffer[ ptr - 1 ] <> 13 ) and ( HostDataBuffer[ ptr - 1 ] <> Delimiter ) HostDataBuffer[ ptr ] := Host.rx ptr++ if ptr > 2 repeat x from ( ptr - 2 ) to 1 if ( HostDataBuffer[ x ] => ( "0" ) ) and ( HostDataBuffer[ x ] =< ( "9" ) ) value := value + ( ( HostDataBuffer[ x ] - "0" ) * place ) place := place * 10 if ( HostDataBuffer[ 0 ] => ( "0" ) ) and ( HostDataBuffer[ 0 ] =< ( "9" ) ) value := value + ( HostDataBuffer[ 0 ] - 48 ) * place elseif HostDataBuffer[ 0 ] == "-" value := value * -1 elseif HostDataBuffer[0] == "+" value := value PUB GetHostHex( Delimiter ) : Value | place, ptr, x, temp {{ Accepts and returns serial hexadecimal values, such as "A2F4" as a number. String must end in a carriage return (ASCII 13) x := Serial.rxHex ' accept string of digits for value }} place := 1 ptr := 0 value :=0 temp := Host.rx if temp == -1 return -1 HostDataBuffer[ ptr ] := Temp ptr++ repeat while ( HostDataBuffer[ ptr - 1 ] <> 13 ) and ( HostDataBuffer[ ptr - 1 ] <> Delimiter ) HostDataBuffer[ ptr ] := Host.rx if HostDataBuffer[ ptr ] == 255 return -1 ptr++ if ptr > 1 repeat x from ( ptr - 2 ) to 0 if ( HostDataBuffer[ x ] => ( "0" ) ) and ( HostDataBuffer[ x ] =< ( "9" ) ) value := value + ( ( HostDataBuffer[ x ]-"0" ) * place ) if (HostDataBuffer[ x ] => ( "a" ) ) and ( HostDataBuffer[ x ] =< ( "f" ) ) value := value + ( ( HostDataBuffer[ x ] - "a" + 10 ) * place ) if ( HostDataBuffer[ x ] => ( "A" ) ) and ( HostDataBuffer[ x ] =< ( "F" ) ) value := value + ( ( HostDataBuffer[ x ]-"A" + 10 ) * place ) place := place * 16 DAT {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}
I think Franklin was asking if it will take 3.3 volt logic levels, since you seem to be trying to interface from a Propeller.
Is this a Parallax #28440 or third party?
