Friendly Consumer alert
Beau Schwabe
So I went to the local hardware store to pick up a speed controller for a ceiling fan.... I wanted the older style with the knob rather than a slider.
For some dumb reason when you turn it "ON" the fan starts out at full speed, and then tapers off as you turn it further to the right. I wanted the opposite mode of operation so I opened the plastic cover. ( Simply take a drill and bore out the brass rivets and the cover comes right off )
I was appalled at the poor point to point solder construction ... I guess I at least expected a circuit board! ... They even used masking tape as an insulator !! I won't give any brand names, but this speed controller is supposedly made in the USA ... Pennsylvania to be specific. (See attached images)
I was able to reverse the operation by swapping the outer leg of the potentiometer, and where the rivets were, I replaced them with 6-32 machine screws.
Now that I know what is "under the hood", I'm still a little uneasy.
Anyway take this however you want with your own grain of salt.
There might be a good reason they did it that way. Two-speed fans are also switched Off->High->Low. I think it's to make sure the motor actually starts before you slow it down. Otherwise it might stall when you first turn it on without giving it the extra kick.
The "Coil" is a small choke around a ferrite rod.
Phil,
"There might be a good reason they did it that way. Two-speed fans are also switched Off->High->Low" ... perhaps, but this application will be driving a sewing machine motor and it starts up just fine.
As far as the workmanship....
It is the use of masking tape for insulation that really has got me wondering. Soldering and then enclosing in a non-conductive, fire retardant box might allow a lot of leeway for other sins, but masking tape is neither reasonalbe insulation nor durable.
Jim
+1, that's how every 3-speed ceiling fan & box fan I've ever seen is wired. I've come to the same conclusion as PhiPi, that it's a safety thing.
However, I suspect the tape is not actually "Masking Tape" which is usually paper based.
It looks to me like a plastic fiber based tape usually used as insulation. Often used by motor winding guys.
As for the U/L is concerned.
They have a hard job to do.
Sometimes they have to just "hold their noses" when stuff like this actually passes the Hy-Pot and other tests.
Hey, it passed, what else can you say.
Duane J
"Good grief, did this device have a UL label ?" - Yes Sir! stamped right on the metal on the front face.
Duane,
"However, I suspect the tape is not actually "Masking Tape"" - It looks, and feels like athletic cloth tape
Personally, I like the brown colored "Kapton" tape but this is a lot more expensive.
Duane J
