Cyril+z basic stamp 2, GPRS shield
Hi there I'm using a GPRS Shield that I wish to connect to the basics stamp to ,I have successfully done that and are able to communicate however a control+Z is required in order to send a text message, The issue is, on normal terminals when you press controll+Z it creates a special character, then it's sent to the program you're using which lets the program know that's z is the end of programming, if I attempt to have the bs2 pass the ASCII equivalent for that symbol it translate to other characters, even if I send it in hex dec bin, same it translate into other characters. So my question would be is there anything I could do even custom custom characters that will make my basic stamp output the symbol for control+Z, seeing that the basic stamp does not recognize the Ctrl+z as an ASCII character. Thanks
Thank you
Always interested in a GSM/GPRS application.
If it is not too much trouble, please can you share your GPRS shied details, connection details and coding?
Many thanks.
