RFID Reader/Writer Spin Issue
I just bought an RFID Reader/Writer on EBay. Great deal since I got it for $36.00 shipped with 2 chips.However, I am unable to get a response from it using the below code on my Propeller BOE Board. I tested it on a BS2 Homework board and Demo code and it worked fine. I am using 5V power from the HW board that is supplied via a wall wart. I also tried to directly plug in to the Prop BOE 5V but I still get nothing. Have tried pretty much all Baud rates although it is suppose to run at 9600. Any help is appreciated.
│ RFID RFID Read/Write Object Wrapper │
│ Author: TinkersALot │
│ Adapted from Joe Grand's BS2 code. │
│ See end of file for terms of use. │
Each RFID card function is tested by entering a specific key on the PST as follows:
Z = test serial number read of legacy card read
S = read new style card serial number
C = try to logon to card (follow the prompts to enter 4 DIGITS password)
D = read all card data (this one seems a bit flakey to me still)
W = write data to card -- not implemented yet in terminal command
P = change the card password ( follow the prompts to enter 4 DIGITS for old and new password ) (needs a bit more testing)
R = Reset the card
U = Unlock the card
L = Lock the card
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000
RFID_TX = 9 ' Connects to RFID R/W Module SIN
RFID_RX = 10 ' Connects to RFID R/W Module SOUT
obj
Host : "FullDuplexSerial"
RFID : "RFID.Reader.Writer.Driver"
var
byte TestBuffer[ 12 ]
byte TestDataBuffer[ 32 * 4 ]
byte OldPwdBuffer[ 4 ]
byte NewPwdBuffer[ 4 ]
byte HostDataBuffer[ 10 ]
PUB TEST_THIS | ErrCheck, CmdByte, LoopCounter, IndexCounter, Offset
Test this driver
' start the host interface ( connected to PST )
ErrCheck := Host.Start( 29, 28, 0, 19200 )
if 0 == ErrCheck
Host.str( string( "Cog Start Error", 13 ) )
else
' since host interface started, the next thing to do is to
' call the driver start method to start its I/O interface
ErrCheck := RFID.Start( RFID_RX, RFID_TX )
if 0 == ErrCheck
' if everything worked above, then enter terminal I/O loop
if ErrCheck <> 0
Host.str( string( "Ready", 13 ) )
repeat
CmdByte := Host.Rx
if CmdByte == $5A ' Z = Legacy read
Host.str( string( "Reading Legacy tag's unique serial number...", 13 ) )
Result := RFID.TryGetLegacyCardNumber( @TestBuffer, 5 )
if Result <> 0
repeat LoopCounter from 0 to 10
Host.hex( TestBuffer[ LoopCounter ], 2 )
Host.str( string( 13 ) )
else
Host.str( string( "Failed to read legacy unique serial number...", 13 ) )
if CmdByte == $53 ' S erial number
Host.str( string( "Reading tag's unique serial number...", 13 ) )
Result := RFID.TryGetCardSerialNumber( @TestBuffer, 5 )
if Result <> 0
repeat LoopCounter from 0 to 4
else
Host.str( string( "Failed to read unique serial number...", 13 ) )
if CmdByte == $43 ' C ard login
Host.str( string( "Trying to logon to card...", 13 ) )
Host.str( string( "Enter 4 digit password", 13 ) )
OldPwdBuffer[ 0 ] := Host.rx - $30
OldPwdBuffer[ 1 ] := Host.rx - $30
OldPwdBuffer[ 2 ] := Host.rx - $30
OldPwdBuffer[ 3 ] := Host.rx - $30
Result := RFID.TryCardLogin( @OldPwdBuffer, 5 )
if Result <> 0
Host.str( string( "Card Logon Succeeded...", 13 ) )
else
Host.str( string( "Card Logon Failed...", 13 ) )
if CmdByte == $44 ' D ata Read
Host.str( string( "Trying to read all card data...", 13 ) )
bytefill( @TestDataBuffer, 0, 128 )
Result := RFID.TryToReadCardData( @TestDataBuffer, 0, 32, 5 )
if Result <> 0
Host.str( string( "Card Data Read Succeeded...", 13 ) )
Host.str( string( "Card Data Dump Follows...", 13 ) )
Offset := 0
repeat LoopCounter from 1 to 32
if LoopCounter < 10
Host.str( string( " " ) )
Host.dec( LoopCounter )
repeat IndexCounter from 0 to 3
Host.hex( TestDataBuffer[ Offset ], 2 )
Offset++
if LoopCounter > 2 and LoopCounter < 32
Host.str( string( " [* writeable]" ) )
Host.str( string( 13, 13, "End Card Data Dump ", 13 ) )
if CmdByte == $57 ' W rite data
Host.str( string( "Trying to write data to card...", 13 ) )
Host.str( string( "Enter address ( 3 to 31 )", 13 ) )
ErrCheck := GetHostDecimal( $0A )
if ErrCheck < 3 or ErrCheck > $1F
Host.str( string( "Invalid address ( range is: 3 to 31 )", 13 ) )
else
Host.str( string( "Will Write To Address: " ) )
Host.dec( ErrCheck )
Host.str( string( "Enter 4 bytes of data ( each byte separated by carriage return)", 13 ) )
OldPwdBuffer[ 0 ] := 0
OldPwdBuffer[ 1 ] := 0
OldPwdBuffer[ 2 ] := 0
OldPwdBuffer[ 3 ] := 0
Result := -1
repeat until Result <> -1
Host.str( string( "Trying To Read Byte 1", 13 ) )
Result := GetHostHex( $0A )
if Result <> -1
OldPwdBuffer[ 0 ] := Result
Host.str( string( "Byte 1 is: " ) )
Host.hex( OldPwdBuffer[ 0 ], 2 )
Result := -1
Host.str( string( "Trying To Read Byte 2", 13 ) )
if Result <> -1
OldPwdBuffer[ 1 ] := Result
Host.str( string( "Byte 2 is: " ) )
Host.hex( OldPwdBuffer[ 1 ], 2 )
Result := -1
Host.str( string( "Trying To Read Byte 3", 13 ) )
if Result <> -1
OldPwdBuffer[ 2 ] := Result
Host.str( string( "Byte 3 is: " ) )
Host.hex( OldPwdBuffer[ 2 ], 2 )
Result := -1
Host.str( string( "Trying To Read Byte 4", 13 ) )
if Result <> -1
OldPwdBuffer[ 3 ] := Result
Host.str( string( "Byte 4 is: " ) )
Host.hex( OldPwdBuffer[ 3 ], 2 )
Result := RFID.TryToWriteDataToCard( ErrCheck, @OldPwdBuffer, 5 )
if Result <> 0
Host.str( string( "Card Data Write Succeeded...", 13 ) )
else
Host.str( string( "Card Data Write Failed...", 13 ) )
if CmdByte == $50 ' P assword set
Host.str( string( "Enter current 4 digit password", 13 ) )
Host.str( string( "Enter new 4 digit password", 13 ) )
NewPwdBuffer[ 0 ] := Host.rx - $30
NewPwdBuffer[ 1 ] := Host.rx - $30
NewPwdBuffer[ 2 ] := Host.rx - $30
NewPwdBuffer[ 3 ] := Host.rx - $30
Result := RFID.TrySetCardPassword( @OldPwdBuffer, @NewPwdBuffer, 5 )
if Result <> 0
Host.str( string( "Card Password Change Succeeded...", 13 ) )
else
Host.str( string( "Card Password Change Failed...", 13 ) )
if CmdByte == $52 ' R eset card
Host.str( string( "Trying to reset card...", 13 ) )
Result := RFID.TryCardReset( 5 )
if Result <> 0
Host.str( string( "Card Reset Succeeded...", 13 ) )
else
Host.str( string( "Card Reset Failed...", 13 ) )
if CmdByte == $55 ' U nlock card
Host.str( string( "Trying to unlock card...", 13 ) )
Result := RFID.TryCardUnlock( 5 )
if Result <> 0
Host.str( string( "Card unlock Succeeded...", 13 ) )
else
Host.str( string( "Card unlock Failed...", 13 ) )
if CmdByte == $4C ' L ock card
Host.str( string( "Trying to lock card...", 13 ) )
Result := RFID.TryCardLock( 5 )
if Result <> 0
Host.str( string( "Card lock Succeeded...", 13 ) )
else
Host.str( string( "Card lock Failed...", 13 ) )
PUB GetHostDecimal( Delimiter ) : Value | place, ptr, x
Accepts and returns serial decimal values, such as "1234" as a number.
String must end in a carriage return (ASCII 13)
x:= Serial.rxDec ' accept string of digits for value
place := 1
ptr := 0
value := 0
HostDataBuffer[ ptr ] := Host.rx
ptr++
repeat while ( HostDataBuffer[ ptr - 1 ] <> 13 ) and ( HostDataBuffer[ ptr - 1 ] <> Delimiter )
ptr++
if ptr > 2
repeat x from ( ptr - 2 ) to 1
if ( HostDataBuffer[ x ] => ( "0" ) ) and ( HostDataBuffer[ x ] =< ( "9" ) )
value := value + ( ( HostDataBuffer[ x ] - "0" ) * place )
place := place * 10
if ( HostDataBuffer[ 0 ] => ( "0" ) ) and ( HostDataBuffer[ 0 ] =< ( "9" ) )
value := value + ( HostDataBuffer[ 0 ] - 48 ) * place
elseif HostDataBuffer[ 0 ] == "-"
value := value * -1
elseif HostDataBuffer[0] == "+"
value := value
PUB GetHostHex( Delimiter ) : Value | place, ptr, x, temp
Accepts and returns serial hexadecimal values, such as "A2F4" as a number.
x := Serial.rxHex ' accept string of digits for value
place := 1
ptr := 0
value :=0
temp := Host.rx
if temp == -1
return -1
HostDataBuffer[ ptr ] := Temp
ptr++
if HostDataBuffer[ ptr ] == 255
return -1
ptr++
if ptr > 1
repeat x from ( ptr - 2 ) to 0
value := value + ( ( HostDataBuffer[ x ]-"0" ) * place )
if (HostDataBuffer[ x ] => ( "a" ) ) and ( HostDataBuffer[ x ] =< ( "f" ) )
value := value + ( ( HostDataBuffer[ x ] - "a" + 10 ) * place )
if ( HostDataBuffer[ x ] => ( "A" ) ) and ( HostDataBuffer[ x ] =< ( "F" ) )
value := value + ( ( HostDataBuffer[ x ]-"A" + 10 ) * place )
place := place * 16
DAT
│ TERMS OF USE: MIT License │
│Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │
│files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │
│modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│
│is furnished to do so, subject to the following conditions: │
│The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│
│THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │
│WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │
│COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │
│ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │
I think Franklin was asking if it will take 3.3 volt logic levels, since you seem to be trying to interface from a Propeller.
Is this a Parallax #28440 or third party?
