An S2 died - probably self inflicted - resurected!
mindrobots
I was curious if anyone had seen this behavior.
I'd been playing with one of my S2s (the one that I had opened to put a 3 wire cable to the outside world form the hacker port) and when I turned it on one time, it did nothing. Swapped batteries and it did nothing. The batteries are good (tested in place with DVM) and the wires to the connector on the rear board are good. I thought they may have gotten "pinched" with the disassembly and reassembly. The dissasembly was over a year ago and it's worked fine since then.
Now, it's just dead. Turned it off once and when I turned it back on (a matter of moments between), it just never came to life. I haven't gone any further with testing (the operating room is full).
Under test at the time was a Trendnet USB to RS232 cable that worked fine for programming when usign the Propeller Tool but wasn't recognizing the Propeller on teh S2 when using the S2 GUI.
Just curious if this has been seen by anyone or if anyone had any quick fix suggestions. I'll dig out the schematics and start pulling it apart when I have the time.
In the mean time, there are other robots calling my name.
It's also good to check for sharks in the water before you jump in. I was just checking to see if anyone had the experience before. Once I get it to a workbench, I'll start probing further to see if is breathing or bleeding!
You have nothing to lose, il mio amico...
Just for info I have removed my S2s sunroof circa 99+ times.... the wiring has a good gauge and plugs high quality, it would take a lot of force to dislodge its intestines...
I wasn't aware of the fuse (thanks!) but as I've been pondering it during the day, I was wondering if it was something like that or a simple switch failure. When you switch the switch, it has no indications of life. Yes, all the connectors seem to be of high quality and actually are hard to remove when you want to. There are a couple places where I have to be careful of wire pinching but "open sunroof" is not a problem.
Edit: It does what I program it to do but unless I program the speaker, motors or LED's it sits there dead when you hit the power switch.
Dave,
YOU ARE A GENIUS!!
That was exactly it. It appears completely dead but you press ahead, plug it in and reload the firmware from the S2 GUI. You get a message about downloading...and a bit later, the blue light comes on and it beeps at you!!
Thank you! This is a good one to remember!
Got me all excited about a customer service opportunity for nothing. . .
Hey Ken,
That reminds me. I sent the details to you about my S2 project. Did you have any feedback?
Andrew, no, I didn't see the message. Could you send it again?
Turns out I haven't done a very good job keeping up with basic communication lately at Parallax.
