BS2 24VAC Propane Furnace Hour Meter
I had the DS1620 near a heat register in my house and I was using a BS2 with USB datalogger to track the temperature over time. I'd like to increase the accuracy of the measurement to determine when and how many hours my furnace is on to monitor my energy usage and compare to the number of gallons I get on propane refills. I wired up a circuit to tap into the 24VAC thermostat wire going to the furnace and to convert the voltage to <5VDC so I can precisely record when the flame is burning. The circuit diagram is attached. I used an adjustable pot to trim the voltage to just below 5 since my 24VAC was not exactly 24VAC where I tapped in. I've tested this circuit with the 24VAC supply and a voltmeter and it does produce 5VDC at the output pin. Before I hook everything up to the furnace and the stamp, I'd like a second opinion on the circuit to make sure I'm sending the stamp a safe current and voltage to read while at the same time causing no disruption to the furnace circuitry. I believe the 24VAC line primarily feeds the relay switches on the furnace control board. I'm treating the thermostat wire as a voltage supply from which I'm pulling next to no load with the 100k resistors. Any feedback would be greatly appreciated!
