MAX232 question
                    Hi, Guys,
I'm trying to interface a MAX232, but i'm unsure if I have the connections right, and i'm not getting any feedback from the serial device. Any recommendations would be grateful.
Cheers,
Cam.
Cheers,
Cam.
See MAX232
Duane J
In any event, can you disconnect the Ardunino and jury rig the Tx to Rx for a loopback test of the Max232. Whatever you typed from your terminal should show up on the screen if the Max232 is working right.
It that is good, you will have to seek advice to what you are doing wrong with your Arduino (likely from elsewhere).
You do seem to have one capacitor that you wired to pins and also short-circuited. And the Max232 has two pairs of Rx and Tx. It seems as if you have inputs on one pair and outputs on another. That won't work.
Frank
I'm sorry about the Arduino stuff, but I also own SX processors and basic stamps
I have the CP2 connected directly from PIN 4 to PIN 5. I couldn't draw it that well. But, on the breadboard its like this:
PIN 4 -> Positive Capacitor pin -> Negative capicitor pin -> PIN 5
Of course there are some capacitors that are not sensitive to polarity and then it doesn't matter. Usually if you put the polarized ones backwards, they blow up with a pop. But I think there is one capacitor on the MAX232 where polarity will work either way. I seem to remember something in the pdf fine print.
Oh, a quick look at the pdf shows that PIN 6 capcitor has a Plus going to Ground and the Minus going to the Pin 6. That might throw you off, the Pin 6 is supposed to output -10 volts, so it is below Ground.
pin 9 is ttl out for the corresponding rs232 in on pin 8
pin 10 is ttl in for corresponding rs232 out on pin 7
Cheers,
If you are going to build serial ports -- either RS232, RS422, RS485; do a physical loopback test before you hook up your microcontroller. It saves time and reduces headaches.
