MCP3208 only reading 1/2 of supplied voltage
I am breadboarding an MCP3208 ADC on a BS2P24/40 demo board and am having a tough time figuring out why the inputs are only reading half of the voltage I'm putting on the input channels.
MCP3208 pin out:
1 (Channel 0) - +5v
2 (Channel 1) - +5v
9 (DGND) - vss
10 (CS) - BS pin 0
11 (DIN) - BS pin 3
12 (DOUT) - BS pin 2
13 (CLK) - BS pin 1
14 (AGND) - vss
15 (VREF) - vdd (+5)
16 (VDD) - vdd (+5)
Code:
When I apply +5v to channel 0 and/or channel 1, it only reads 2.502v (2047 in 12-bit) on the debug screen. The +5vdc on channels 0 and 1 is coming from VDD on the demo board (so the same as the supply for the chip, but that shouldn't matter?) This is originally code from a MCP3202, which didn't work until I altered the SHIFTOUT string. Is there something else in the code that isn't compatible with the 3208? Anyone see anything?
Benj
MCP3208 pin out:
1 (Channel 0) - +5v
2 (Channel 1) - +5v
9 (DGND) - vss
10 (CS) - BS pin 0
11 (DIN) - BS pin 3
13 (CLK) - BS pin 1
14 (AGND) - vss
16 (VDD) - vdd (+5)
Code:
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
CS PIN 0 ' Chip Select
Clock PIN 1 ' Clock
DataOut PIN 2 ' DOUT
DataIn PIN 3 ' DIN
' -----[ Constants ]-------------------------------------------------------
Cnts2Mv CON $0139 ' x 1.22 (To Millivolts)
Start_bit CON 1
SE_0 CON %1000
SE_1 CON %1001
' -----[ Variables ]-------------------------------------------------------
result0 VAR Word ' Conversion Result CH0
result1 VAR Word ' Conversion Result CH1
mVolts0 VAR Word ' Result0 --> mVolts
mVolts1 VAR Word ' Result1 --> mVolts
' -----[ Init Setup ]------------------------------------------------------
DEBUG CLS, "ADC CH 0 : ", CR, "Volts :", CR,
"ADC CH 1 : ", CR, "Volts :"
' -----[ Program Code ]----------------------------------------------------
DO
LOW CS ' Enable ADC
SHIFTOUT DataIn, Clock, MSBFIRST, [Start_bit\1, SE_0\4] ' Select CH0, Single-Ended
SHIFTIN DataOut, Clock, MSBPOST, [result0\12] ' Read ADC
HIGH CS ' Disable ADC
mVolts0 = result0 */ Cnts2Mv ' Convert To Millivolts
LOW CS ' Enable ADC
SHIFTOUT DataIn, Clock, MSBFIRST, [Start_bit\1, SE_1\4] ' Select CH1, Single-Ended
SHIFTIN DataOut, Clock, MSBPOST, [result1\12] ' Read ADC
mVolts1 = result1 */ Cnts2Mv ' Convert To Millivolts
DEBUG HOME, CRSRXY, 11, 0, DEC result0, CLREOL, ' Displays voltages & digital value
CRSRXY, 11, 1, DEC mVolts0 DIG 3, ' for both channels
".", DEC3 mVolts0,
CRSRXY, 11, 2, DEC result1, CLREOL,
CRSRXY, 11, 3, DEC mVolts1 DIG 3,
".", DEC3 mVolts1
PAUSE 100
LOOP
Benj
'************************************* '* ADC Section * '************************************* ' CHAN 0 chan = 0 adc_cmd = chan + %11000 high spi_cs0 low spi_cs0 shiftout spi_tx, spi_clk, msbfirst, adc_cmd\5, so_speed shiftin spi_rx, spi_clk, msbpost, adc_cnt\13, so_speed low spi_clk wrlong ADC_0_H,adc_cnt 'multiply by 1.22 to get mv based on 5 volt vRef ' CHAN 1 chan = 1 adc_cmd = chan + %11000 high spi_cs0 low spi_cs0 shiftout spi_tx, spi_clk, msbfirst, adc_cmd\5, so_speed shiftin spi_rx, spi_clk, msbpost, adc_cnt\13, so_speed low spi_clk wrlong ADC_1_H,adc_cnt 'multiply by 1.22 to get mv based on 5 volt vRef
So Benj - that's good news! Care to mark your thread as "solved"?
