DC-DC Step Down Converter
I think @erco or someone else posted this link a few weekes back but I could not find it. http://www.ebay.com/itm/1pcs-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-/251066005460?pt=LH_DefaultDomain_0&hash=item3a74b337d4
I just received the 4 I ordered a couple days ago and was so impressed I ordered 6 more. There's only 4 days left to get them for $1.78 and $1.00 shipping.
The LM2596S-ADJ no lead IC itself sells for over $4 at DigiKey or Jameco.
Not sure if the eBay unit is lead free
Well it was on the .co.uk ebay site so can't say.
If the pictures in the eBay ad are to be believed, the unit is capable of sourcing at least 12 watts.
I absolutely love them and use them constantly. Back-in-the-day, the average multi-turn pot was pretty lousy. They had a lot of backlash and it was difficult to target a specific setting. The pots they're putting on these boards are fabulous!
Depending on the supply voltage, the output of these units may wander a couple hundredths of a volt. That's the biggest criticism I can wage, and it's nothing.
...you guessed it...
... a buck... $1.01 anyway.
http://www.ebay.com/itm/1-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-T7-/121208203049
3 pots allow adjustment for CV & CC. Potential uses are battery chargers (multi type) and LED drivers. 3A max current
Gotta have one.
Simple one, when giving 5V 1A from 12V input - heats quite much, input capacitor is burning hot.
CC/CV one - no matter what current limit you'll set, it will switch off if output current is more than 1.34A (12VDC input, 5VDC output).
So never going to order them again.
Here are exact URLs to ones I've purchased:
http://www.ebay.com/itm/111146952543?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.com/itm/DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-/181227591312?pt=LH_DefaultDomain_0&hash=item2a32019690
http://www.ebay.com/itm/251210465283?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
These are cheapo cut-off wheels for dremel. They are cheap, yes, but they are weak, too. To cut one 1/8 screw, you need one such disk, it wears so fast! With genuine dremel disc, you can cut at least 5 pieces of 1/8 screws with it.
http://www.pololu.com/category/84/regulators-and-power-supplies
http://www.ebay.com/itm/150W-DC-DC-Boost-Converter-10-32V-to-12-35V-Step-Up-Voltage-Charger-Power-/121240568896?pt=LH_DefaultDomain_2&hash=item1c3a804440
It can't deliver full power under various conditions. For example, when generating 24V from 12V input, the maximum current you get is around 4A, which is less than stated 150W. Also, input capacitor heated so much, that it exploded.
