How to? Create an array of arrays
Given my low experience level, this may seem like a peculiar question. Can I create an array of arrays? I am trying to start several of the same type objects in different cogs.
The brute force method looks like this, and works just fine. It starts as many cogs as remain and blinks LEDs:
When I got to the point where I wrote ??? I realized I was in a pickle. I need an array of arrays, I think. Can that be done?
Best Regards,
Steve
var
byte Cog [8]
long LED16Stack[10],LED17Stack[10],LED18Stack[10],LED19Stack[10],LED20Stack[10],LED21Stack[10],LED22Stack[10],LED23Stack[10]
pub cog_counter
'' starts blink led in each remaining cog
start16 'Launched into cog 1
start17 'Launched into cog 2
start18 'Launched into cog 3
start19 'Launched into cog 4
start20 'Launched into cog 5
start21 'Launched into cog 6
start22 'Launched into cog 7
start23
pub blink_led(pin)
dira[Pin]~~ ' make pin output
repeat
!outa[pin]
waitcnt(clkfreq/(pin-15)+cnt) 'Subtracting 15 makes the cogs blink at a rate you can observe
pub start16
stop16
Cog[1]:= cognew(blink_led(16),@LED16Stack)+1
pub stop16
if cog[1]
cogstop(cog[1]~ - 1)
pub start17
stop17
Cog[2]:= cognew(blink_led(17),@LED17Stack)+1
pub stop17
if Cog[2]
cogstop(cog[2]~ - 1)
pub start18
stop18
Cog[3]:= cognew(blink_led(18),@LED18Stack)+1
pub stop18
if Cog[3]
cogstop(Cog[3]~ - 1)
pub start19
stop19
Cog[4]:= cognew(blink_led(19),@LED19Stack)+1
pub stop19
if Cog[4]
cogstop(Cog[4]~ - 1)
pub start20
stop20
Cog[5]:= cognew(blink_led(20),@LED20Stack)+1
pub stop20
if Cog[5]
cogstop(cog [5]~ - 1)
pub start21
stop21
Cog[6]:= cognew(blink_led(21),@LED21Stack)+1
pub stop21
if Cog[6]
cogstop(cog [6]~ - 1)
pub start22
stop22
Cog[7]:= cognew(blink_led(22),@LED22Stack)+1
pub stop22
if Cog[7]
cogstop(cog [7]~ - 1)
pub start23
stop23
Cog[8]:= cognew(blink_led(23),@LED23Stack)+1
pub stop23
if cog [8]
cogstop(cog [8]~ - 1)
So I decided to tighten it up a bit and began to write:
byte Cog [8]
pub cog_counter | n,startpin
startpin := 16
repeat n from 1 to 8
dira[n+(startpin-1)]~~ 'set pin to output
if cog[n] 'standard cogstop routine
cogstop(cog[n]~ -1)
Cog[n]:=cognew(blink_led(n+(startpin-1)),@???)+1 'start next cog
Best Regards,
Steve
var long StackArea[7 * 10]
cog[ n ] := cognew( blink_led( n + startpin ), @StackArea + 4*10*n )
Note that n has to range from 0 to 6 for this to work
I curious about why you want so many cogs to blink LEDs?
I have an object which uses one cog to blink up to 32 LEDs all at different rates.
If the LEDs are just being used to learn about using multiple cogs then have at it.
However, if this is really about blinking LEDs, you shouldn't need more than one cog to do so. Let me know if there's anything about the LED object you don't understand.
Here's the appnote:
http://www.parallaxsemiconductor.com/sites/default/files/appnotes/AN003-AbstractDataStructures-v1.0_1.pdf
Thank you for the responses. I am taking some quiet time here between episodes of shoveling the driveway to create a template object for my own use and get a better understanding of ViewPort and FullDuplexSerial4Port. To that template I decided to add a "cogs remaining" method. I originally did this with my robomagellan project to determine how many cogs I had remaining. The brute force approach works but I thought I could do it in a more "elegant" manner.
Best Regards,
Steve
First, I presume the statement StackArea[7*10] essentially means the we are creating 7 arrays each of 10 longs. Makes sense, but why @StackArea + 4*10*n? The 4 works, but I dont know why.
Second, and this is what really has me confused, I originally created byte Cog[7] assuming that I would need the 7 bytes for the cog names. Just for giggles I reduced it to Cog[6], with no effect, and kept reducing to just byte Cog. Same effect each time, all the leds blink for the remaining cogs. I thought I understood this, but clearly I do not.
Steve
var byte Cog'[0] ' create 7 byte size variables named cog[0] - cog[6] long StackArea[7*10] ' create 7-10 long sized arrays named StackArea pub cog_counter | n,startpin '' starts blink led in each remaining cog startpin := 16 repeat n from 0 to 6 dira[n+startpin]~~ ' set pin to output if Cog[n] ' standard cogstop routine cogstop(cog[n]~ -1) Cog[n]:=cognew(blink_led(n+startpin),@StackArea + 4*10*n)+1 ' start next cogNo not really, Spin/Pasm use absolute addressed for variables that never move or have gaps.
So when you pass an address along with cognew , it's simple the start address of a block of the hub ram of your choice.
So you really are creating 70 longs reserved space (on big block) and it's up to you how you want to treat it.
You could interleave or space each sub-block 10 longs apart etc.
The "4" is because there are four bytes in a long. Hub RAM is addressed as bytes. While you have seven groups of 10 longs, you also have seven groups of 40 bytes.
There is a lot of empty RAM with a small program. Your six extra variables where in the memory located right after where "Cog" is stored. Theres a good chance writing to this memory wouldn't have a noticeable effect on the program. But this is not a good idea. It can easily cause you trouble.
Did you see my recent thread on stack space? There's a program there that dumps the contents of the stack space assigned to a cog. I found the exercise very instructive.
Likewise the StackArea variable array need only be sized to run in one COG. StackArea[10] is sufficient given the simple nature of the method and there is no need to try and anticipate 7 instances of the method call in the form StackArea[70].
Best Regards
Steve
If I understand you correctly then you do not understand correctly.
I don't have time to explain. Hopefully someone else can jump in.
Ive reread all the posts and as an educational exercise, I decided to create a few experiments each with the intention of accomplishing the same task of starting COG's. The programs can be run without modification on demo or QuickStart boards.
The first is pretty straight forward with seven stack arrays and seven cog IDs to support the starting of the seven remaining cogs. Size: 83 Longs program 72 Longs variables.
var long Cog0Stack[10], Cog1Stack[10],Cog2Stack[10], Cog3Stack[10], Cog4Stack[10], Cog5Stack[10], Cog6Stack[10] byte CogID_0, CogID_1, CogID_2, CogID_3, CogID_4, CogID_5, CogID_6 pub main start16 ' launched into cog 1 start17 ' launched into cog 2 start18 ' launched into cog 3 start19 ' launched into cog 4 start20 ' launched into cog 5 start21 ' launched into cog 6 start22 ' launched into cog 7 pub blink_led(pin) dira[Pin]~~ repeat !outa[pin] waitcnt(clkfreq/(pin-15)+cnt) pub start16 stop16 CogID_0:= cognew(blink_led(16),@Cog0Stack)+1 pub stop16 if CogID_0 cogstop(CogID_0~ - 1) pub start17 stop17 CogID_1:= cognew(blink_led(17),@Cog1Stack)+1 pub stop17 if CogID_1 cogstop(CogID_1~ - 1) pub start18 stop18 CogID_2:= cognew(blink_led(18),@Cog2Stack)+1 pub stop18 if CogID_2 cogstop(CogID_2~ - 1) pub start19 stop19 CogID_3:= cognew(blink_led(19),@Cog3Stack)+1 pub stop19 if CogID_3 cogstop(CogID_3~ - 1) pub start20 stop20 CogID_4:= cognew(blink_led(20),@Cog4Stack)+1 pub stop20 if CogID_4 cogstop(CogID_4~ - 1) pub start21 stop21 CogID_5:= cognew(blink_led(21),@Cog5Stack)+1 pub stop21 if CogID_5 cogstop(CogID_5~ - 1) pub start22 stop22 CogID_6:= cognew(blink_led(22),@Cog6Stack)+1 pub stop22 if CogID_6 cogstop(CogID_6~ - 1)The second program is intended to do the same thing in a more streamlined manner, and incorporates Mike Greens recommendation regarding the allocation of the reserved stack space. If I understand, each subsequent Cog[n] runs in an @StackArea memory location offset by 40*n bytes from the previous. Size: 23 Longs program 72 Longs variables.pub cog_counter | n,startpin '' starts blink led in each remaining cog startpin := 16 repeat n from 0 to 6 dira[n+startpin]~~ if Cog[n] cogstop(cog[n]~ -1) Cog[n]:=cognew(blink_led(n+startpin),@StackArea + 4*10*n)+1 ' start next cog pub blink_led(pin) dira[Pin]~~ repeat !outa[pin] waitcnt(clkfreq/(pin-15)+cnt)The last is a pair of programs; the second is called by the first seven times. I will not risk trying to explain why it works! Size: 37 Longs program 77 Longs variables.
Anyway, I think Ive developed a bit better understanding, and maybe this might just help someone else along.
Steve
var long CogStack[10] byte Cog pub start(pin) stop(pin) Cog:= cognew(blink_led(pin),@CogStack)+1 pub blink_led(pin) dira[pin]~~ repeat !outa[pin] waitcnt(clkfreq/(pin-15)+cnt) pub stop(pin) if Cog cogstop(Cog~ - 1)
