Propeller demo board won't read from eeprom without USB being attached
I have a propeller demo board and just recently realized that it won't load and run a program from eeprom unless attached to the computer's USB port. The propeller tool doesn't need to be running, I think it just needs USB power. Is this normal behavior for the demo board or have I blown something? I usually just write to RAM, but now have a project where I want it to start up and do its thing when I turn on the power.
Thanks in advance,
Red_Dog
Thanks in advance,
Red_Dog
If you have a serial console on the terminal, it will reset the prop if the usb is not connected.
if you are using propeller serial terminal OBC created a pst dummy object. Simply place it in the same director, modify the object name, and the console is not used. no need to comment out the pst calls.
No more resets.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDgQFjAA&url=http%3A%2F%2Fforums.parallax.com%2Fattachment.php%3Fattachmentid%3D70219%26d%3D1273608817&ei=VEvNUo60CoX_ygOKxYDYCQ&usg=AFQjCNHKezANqEaRFaQHlSfngyyTcAVe9A&sig2=UI3K0Rc-9a4lmAi0SCdwrg&bvm=bv.58187178,d.bGQ&cad=rja
thanks again,
Red_dog
But removing the PST output to the USB port is not desirable, as I write some diagnostics and a banner line on startup, so I know what version is running.
I don't have this problem with the Propeller Professional Development Board (PPDB), and it uses the same FT232RQ chip according to the schematic. The only difference I can see is that the PPDB has a 33k pulldown resistor at the base of the reset transistor, and the PDB has a 10k pulldown resistor. Is this what is causing the problem on the PDB? Would replacing the 10k resistor with a 33k resistor fix it?
I don't know if you've seen this thread or not but it lists a couple different options.
I didn't see it mentioned in the above thread, but one option is to monitor the rx line to see if it's "live" when the program starts. If the line isn't active, the program sets a flag and doesn't use any of the debug statements.
