Ulcd32-PTU demo question — Parallax Forums
w4fejw4fej Posts: 264
edited 2014-01-06 09:30 in Propeller 1
I'm trying to get the demo running on my Prop development board with no success. My question is what configuration should the display itself be in ? I have a simple Visi Genie app on the SD card and when powered up it displays that splash screen. When I run the demo the display blanks (I assume that's the reset in action) then the app splash screen comes back up and that's the end of it.
I know very little about the display at this time so it's entirely possible I have it setup wrong the demo. By the way, the Prop tool reports a good compile and download.. I just updated the PMMC to the display and it also reported success.
Anyone got the demo to run on their display??
Thanks, Mike B.
    edited 2014-01-06 09:21
    Mike I have a 4.3" non-touch version of this LCD. When Powered up without a SD card inserted what does the splash screen say? If it has been set to another mode you can use the 4D workshop tool to set it up for serial mode.
    That is considering your trying to run Beau's demo in the OBEX?
    The DEMO for the Display runs the demo code in the serial configuration mode... there is a video located here: http://www.youtube.com/watch?v=ZIlAoABmQ0w
