New chip for recharging large battery packs.
LoopyByteloose
Sometime last year, I looked into balancing and managing the charge of large Lithium battery packs intended for electric bicycles. I felt the industry was off in the weeds and that nearly everything had been removed from production and sales due to unspecified problems.
And so, it seemed that a simple charger was best if it worked with a simple cutoff to protect the cells.
I just came across a new chip that uses a matrix of transformers and this seems to move ahead of what was being done. It may be a significant breakthrough. I can't be sure, but I know other here will be a good critical review of its utility.
LT3791 100W boost/buck converter before, and use the LTC6912 programmable gain rail-to-rail amps.
I really ought to trawl their product list sometime to see what I'm missing!
This example is clearly aimed at electric traction battery management with the 10A balance current rating.
Marty
