Is "repeat until not" better, worse or the same as "repeat while"
Consider the following statement:
Does the above statement require more, less or the same execution time and memory than the following statement?
repeat until not lockset(namelock)
repeat while lockset(namelock)
Here is the output a bit simplified: I would say that the WHILE version is faster because UNTIL NOT needs one bycode more. The other bytecodes are similar.
Andy
