Is "repeat until not" better, worse or the same as "repeat while"
dbpage
Consider the following statement:
Does the above statement require more, less or the same execution time and memory than the following statement?
repeat until not lockset(namelock)
repeat while lockset(namelock)
Here is the output a bit simplified:
repeat until not lockset(namelock) Addr : 0018: 36 : Constant 2 $00000001 Addr : 0019: 2A : LockSet(Id) Push Addr : 001A: FF : Math Op NOT Addr : 001B: 0B 02 : jnz 001F +2 Addr : 001D: 04 79 : Jmp 0018 -7 repeat while lockset(namelock) Addr : 001F: 36 : Constant 2 $00000001 Addr : 0020: 2A : LockSet(Id) Push Addr : 0021: 0A 02 : jz 0025 +2 Addr : 0023: 04 7A : Jmp 001F -6I would say that the WHILE version is faster because UNTIL NOT needs one bycode more. The other bytecodes are similar.Andy
