Using multiple eeprom chips for program storage, with BS2 OEM ?
Hello. Is such thing possible? I want to make one board with bs2 oem, but add several eeprom chips, so I can run several large programs from separate chips when needed. I think of adding some rotary switch or multiplexer chip, to select proper eeprom when needed. Will this work?
You could have multiple devices on the clock and data lines.
All you would have to do is add a DIPswitch to enable (A0,A1,A2 low) the desired device via the Address lines.
OT: I purchased the Hydra (on sale) because the manual was sold out and the only way to get the manual was by purchasing the full system. Now the manual is available as a free download. Lot's of great stuff in the manual (mostly Propeller specific).
