Quickstart VGA socket ?
AGCB
Hi
I'm trying to add a VGA socket to my Quickstart board and I have determined all the pin routing except the pin 9 on the VGA socket. One schematic shows it tied to 5V and another to ground. Which should it be? I'm allergic to smoke, especially expensive smoke!
Aaron
Aaron
Aaron
On a PC (etc) the +5V is used to power up a EEPROM in the VGA monitor, SDA and SCL go down pins 12 and 15. This allows the PC to know what the monitor is even if it is un-powered. Obviously the Prop doesn't do any of that.
Some connectors do a lazy thing and just connect all of the middle row to deck, great until something that has the +5v on pin 9 gets plugged to it ! A lot of connectors/leads have that pin missing to prevent problems.
I tend to leave it O/C on the Prop boards, but it could be useful as a way to get +5V off the board for external things, for that I usually pick it off of a PS2 Keyboard connection if there is one.
Alan
PS Merry Christmas to all
[/QUOTE]
Speaking of PS/2, that's the next thing I want to add. I assume just the clock and data pins and the ground for a mouse and keyboard. Is that right? I have both a mouse and keyboard that I want to connect to the Quickstart.
Thanks again
Aaron and Merry Christmas from here too!
Aaron
edit: since it's 5V, does there need to be input protection for the Prop? series resistor or?
I would start from that.
Massimo
Aaron
