simple product needed I have $100(garage thermostat)
If anyone is interested in making 1 I am interested in buying.
I need simple faceless thermostat which I can set a temperature between 0 and 63 deg Fahrenheit with dip switches. it must be able to mount inside a standard electrical box(I can provide drawings) I can provide 3 wire power(12v, heat, ground)
PS - What quantity do you want?
I personally only need 1 but may be able to sell a few to friends. and hopefully designer can sell lots
Add a dip switch and tailored resistances and you are (almost) set....
Massimo
Thanks for posting that, it is probably a better solution than what I had in mind, and I might have a use for it in another application.
Using analog device tmp01 this is my modification of diagram 18 on page 11 of data sheet. Will it work any thoughts?
