Function pointer array warnings
I am working on some code that uses a couple of function pointer arrays. I want to initialize these arrays at compile time. The following code works, but it generates a pile of warning messages.
Thanks.
#define _CHAR_TOKENS 9 #define _CHAR_STATES 4 int main(void) { /* fsm fuctions */ int char_nop(char *,char **); // 0 int char_esc(char *,char **); // 1 int char_add_char(char *,char **); // 2 int char_remove(char *,char **); // 3 int char_add_dlim(char *,char **); // 4 int char_add_quote_char_process(char *,char **); // 5 int char_add_process(char *,char **); // 6 int char_delim_add(char *,char **); // 7 int char_eof_process(char *,char **); // 8 /* character processor action table - initialized with fsm fuctions */ typedef void (*ACTION_PTR)(char *,char **); ACTION_PTR char_action[_CHAR_TOKENS][_CHAR_STATES] = { /* ESC */ {char_esc, char_esc, char_esc, char_esc }, /* SPACE */ {char_nop, char_add_char, char_add_char, char_nop }, /* COLON */ {char_nop, char_add_char, char_add_char, char_nop }, /* SLASH */ {char_nop, char_add_char, char_add_char, char_nop }, /* BSPACE*/ {char_nop, char_remove, char_remove, char_remove }, /* QUOTE */ {char_add_char, char_add_dlim, char_delim_add, char_delim_add }, /* CR */ {char_nop, char_add_quote_char_process, char_add_process, char_add_process }, /* other */ {char_add_char, char_add_char, char_add_char, char_add_char }}; /* character processor state transition table */ int char_new_state[_CHAR_TOKENS][_CHAR_STATES] ={ /* ESC */ {0, 0, 0, 0}, /* SPACE */ {0, 1, 3, 3}, /* COLON */ {0, 1, 3, 3}, /* SLASH */ {0, 1, 3, 3}, /* BSPACE*/ {0, 1, 2, 3}, /* QUOTE */ {1, 3, 1, 1}, /* CR */ {0, 0, 0, 0}, /* other */ {2, 1, 2, 2}}; return 0; }
Project Directory: /Users/mam1/Documents/GCC Master/post/ propeller-elf-gcc -v GCC 4.6.1 (propellergcc_v1_0_0_2224) propeller-elf-gcc -I . -L . -o cmm/post.elf -Os -mcmm -Wall -m32bit-doubles -fno-exceptions -std=c99 post.c post.c: In function 'main': post.c:24:13: warning: initialization from incompatible pointer type [enabled by default] post.c:24:13: warning: (near initialization for 'char_action[0][0]') [enabled by default] post.c:24:13: warning: initialization from incompatible pointer type [enabled by default] post.c:24:13: warning: (near initialization for 'char_action[0][1]') [enabled by default] post.c:24:13: warning: initialization from incompatible pointer type [enabled by default] post.c:24:13: warning: (near initialization for 'char_action[0][2]') [enabled by default] post.c:24:13: warning: initialization from incompatible pointer type [enabled by default] post.c:24:13: warning: (near initialization for 'char_action[0][3]') [enabled by default] post.c:25:13: warning: initialization from incompatible pointer type [enabled by default] post.c:25:13: warning: (near initialization for 'char_action[1][0]') [enabled by default] post.c:25:13: warning: initialization from incompatible pointer type [enabled by default] post.c:25:13: warning: (near initialization for 'char_action[1][1]') [enabled by default] post.c:25:13: warning: initialization from incompatible pointer type [enabled by default] post.c:25:13: warning: (near initialization for 'char_action[1][2]') [enabled by default] post.c:25:13: warning: initialization from incompatible pointer type [enabled by default] post.c:25:13: warning: (near initialization for 'char_action[1][3]') [enabled by default] post.c:26:13: warning: initialization from incompatible pointer type [enabled by default] post.c:26:13: warning: (near initialization for 'char_action[2][0]') [enabled by default] post.c:26:13: warning: initialization from incompatible pointer type [enabled by default] post.c:26:13: warning: (near initialization for 'char_action[2][1]') [enabled by default] post.c:26:13: warning: initialization from incompatible pointer type [enabled by default] post.c:26:13: warning: (near initialization for 'char_action[2][2]') [enabled by default] post.c:26:13: warning: initialization from incompatible pointer type [enabled by default] post.c:26:13: warning: (near initialization for 'char_action[2][3]') [enabled by default] post.c:27:13: warning: initialization from incompatible pointer type [enabled by default] post.c:27:13: warning: (near initialization for 'char_action[3][0]') [enabled by default] post.c:27:13: warning: initialization from incompatible pointer type [enabled by default] post.c:27:13: warning: (near initialization for 'char_action[3][1]') [enabled by default] post.c:27:13: warning: initialization from incompatible pointer type [enabled by default] post.c:27:13: warning: (near initialization for 'char_action[3][2]') [enabled by default] post.c:27:13: warning: initialization from incompatible pointer type [enabled by default] post.c:27:13: warning: (near initialization for 'char_action[3][3]') [enabled by default] post.c:28:13: warning: initialization from incompatible pointer type [enabled by default] post.c:28:13: warning: (near initialization for 'char_action[4][0]') [enabled by default] post.c:28:13: warning: initialization from incompatible pointer type [enabled by default] post.c:28:13: warning: (near initialization for 'char_action[4][1]') [enabled by default] post.c:28:13: warning: initialization from incompatible pointer type [enabled by default] post.c:28:13: warning: (near initialization for 'char_action[4][2]') [enabled by default] post.c:28:13: warning: initialization from incompatible pointer type [enabled by default] post.c:28:13: warning: (near initialization for 'char_action[4][3]') [enabled by default] post.c:29:13: warning: initialization from incompatible pointer type [enabled by default] post.c:29:13: warning: (near initialization for 'char_action[5][0]') [enabled by default] post.c:29:13: warning: initialization from incompatible pointer type [enabled by default] post.c:29:13: warning: (near initialization for 'char_action[5][1]') [enabled by default] post.c:29:13: warning: initialization from incompatible pointer type [enabled by default] post.c:29:13: warning: (near initialization for 'char_action[5][2]') [enabled by default] post.c:29:13: warning: initialization from incompatible pointer type [enabled by default] post.c:29:13: warning: (near initialization for 'char_action[5][3]') [enabled by default] post.c:30:13: warning: initialization from incompatible pointer type [enabled by default] post.c:30:13: warning: (near initialization for 'char_action[6][0]') [enabled by default] post.c:30:13: warning: initialization from incompatible pointer type [enabled by default] post.c:30:13: warning: (near initialization for 'char_action[6][1]') [enabled by default] post.c:30:13: warning: initialization from incompatible pointer type [enabled by default] post.c:30:13: warning: (near initialization for 'char_action[6][2]') [enabled by default] post.c:30:13: warning: initialization from incompatible pointer type [enabled by default] post.c:30:13: warning: (near initialization for 'char_action[6][3]') [enabled by default] post.c:31:13: warning: initialization from incompatible pointer type [enabled by default] post.c:31:13: warning: (near initialization for 'char_action[7][0]') [enabled by default] post.c:31:13: warning: initialization from incompatible pointer type [enabled by default] post.c:31:13: warning: (near initialization for 'char_action[7][1]') [enabled by default] post.c:31:13: warning: initialization from incompatible pointer type [enabled by default] post.c:31:13: warning: (near initialization for 'char_action[7][2]') [enabled by default] post.c:31:13: warning: initialization from incompatible pointer type [enabled by default] post.c:31:13: warning: (near initialization for 'char_action[7][3]') [enabled by default] post.c:34:5: warning: unused variable 'char_new_state' [-Wunused-variable] post.c:23:12: warning: unused variable 'char_action' [-Wunused-variable] propeller-load -s cmm/post.elf propeller-elf-objdump -h cmm/post.elf Done. Build Succeeded! propeller-load -S1 -Dreset=dtr -I /opt/parallax/propeller-load/ cmm/post.elf -r -p /dev/cu.usbserial-004213FAPropeller Version 1 on /dev/cu.usbserial-004213FA Loading cmm/post.elf to hub memory 2268 bytes sent Verifying RAM ... OKIs there a better way to initialize a function pointer array at compile time that does not generate all these warning messages? Or is there a way to turn off warnings for just one file? I like to keep warnings on while I am developing.
Thanks.
