What happened with quick start??
This webpage tutorial helps in no way
http://learn.parallax.com/KickStart/27911
I was so intent on making it work too!
And the items used stated the two were compatible needs no other product to use..
...this evening I spent nearly $100.00 I feel taken a lot!!
Say, the pin outs not the same what to do?
The info on this website is not of use. Additionally The package stated the unit together were ready to use and further that all components were there too.
I found I had to go back and get a small bread board...
The small I/O pins are not numbered at all I am perplexed at what $100 won't buy!
More, I use only Apple OS-X and I am not sure that the interface works or exactly how to go about using the programs because Radio Shack was unsure I should buy these for that reason - It si NOT stated clearly enough to encourage mulit-platform users at all.
Radio Shack prices are about 10% higher than on your own website too when I saw it here... after purchase..
I read also that to make this Gyroscope application work even better one needs to BUY an accelorometer module... can I get by without?
Is there a module that contains both the accelerometer and 3 D gyro function together Or is there some code, prewritten that I can download for all?
http://www.ebay.com/itm/MPU-6050-6DOF-3-Axis-Gyroscope-Accelerometer-Module-for-Arduino-DIY-/181279316297?pt=LH_DefaultDomain_0&hash=item2a3516d949
I'd like to tell the company that they should attend to this issue soon!
I wanted a WORKING PROJECT as soon as I got home..
Well it is almost 2014 a long while since my vocational electr. tech courses in 1990
DOS 3.3 monochrome monitor and Intel 4.7Mhz processor I had then to look at.
You could do massive toe damage if you should drop that thing!! Any part of it!!!
6 inch floppy disc drive later 1.44 3 inch drive...
When I attended school then and first saw this Brontosaurus computer I thought the 1300s had past by now...
I mean you guys and Aurdrino see that?
That would be a really good start for anyone here to understand what you have there.
I did get that auction on e-bay for the accelerometer - 3-D Gyroscope Arduino module and
I may ask if there are any smart people here that can assist in powering up the Parallax Q/S and this?
Contact Parallax support. http://www.parallax.com/support
Here you go.
That is known as the price of immediate convenience.
Don't we all.
1. Research the "modules" that you are going to use before you purchase them. This will give you insight into how these pieces of the puzzle will mate together.
2. Before you order give it a second look. The shipping cost for a 0.1 cap that you forgot to order could have been easily added to the order and paid for many dust collectors for the parts bins.
3. Spend the time that you have while waiting for the modules to arrive by studying the documentation for the modules so when they arrive you have a running start to piece them together.
4. Be thankful for the advice and teachings of those that give it. These people truly are the living example of the "teach a man to fish" philosophy.
Hope this helps.
traVis.
Don't your RS have 'Spend $50 get $10' ?, that's a 20% kickback right there.
http://www.radioshack.com/graphics/uc/rsk/USContent/HTML/pages/hbfaq.html
There are a lot of smart and helpful people on this forum that can help you with your project, but they need to know what parts you have and what you want to accomplish.
Post a list of the parts (part number and supplier) along with a picture and link to the part site if possible, then a description of what you want to do with those parts. Emulating a 3-D gyroscope could mean anything from displaying the X, Y, Z angles to controlling the maneuvers of an RC plane, multiple rotor copter, or a robot. You need to give more detail to get the most help from the forum members.
PS, the QS will work with either of the gyro modules in your post.
