device to measure a force (gauge strain )
Hi
I have a project to finish in 3 months
my project is basically about measuring the stiffness of the tissue and I am in process of making a device or a technique for it
So basically I am going to design a beam that is attached to a wall which is suppose to be bendable in order to position the gage strain on this beam
this beam in a way will hold the tissue in 4 directions and I will put a load over the membrane the memberane will deform and the beam suppose to get bent and gauge strain will get me the value of voltage
the dimension of the beam is undefined .. I dont know how small should it be designed...what i know is the gauge strains are in mm so should i design a beam in mm or cm ..I am really confused about it
the tissue that I am measuring is a cancer cell
Since this is my first time doing this kind of project ..I have no idea which gauge strain should i use ? and what type of the bendable beam can I design
I thought of Polycarbonates material .but I am not sure if the load that i will apply to tissue which is less than gram (i dont if this is even correct but what i mean is ..it will be a small load over the membrane ) is enough to make the beam bendable
I hope u can advise me here
Thank you So much
Thank you So much
polystyrene (probably too brittle anyway). Thin metal isn't to be ignored either, stainless spring steel might be worth investigating.
Thank you So much for your reply .. I really appreciate it
So what I meant by bendable that I need a flexible beam ..So did u mean that metal could be flexible too
I have question regerd the gauge strain ..Is there any specific type of gauge strain the provide me the force value instead of voltage ?
I do know there are some load cells with built in electronics that output force directly but have not come across any strain gauges that do so.
[that means bags of CMRR and PSRR and ultra-low offset voltage and offset-voltage drift]
Better yet are the chips designed to work with strain gauges. There are single chip systems that include the excitation, amplifier, adc, and digital interface.
Interesting project!
Erlend
