problem with program
Hi,
i made a program but it did´t work so i tried to cut it as mutch as possible to see what actually working
Now i have got just this size of program and i don´t get it when the program starts there are no signal on pins 0-7 (i checked it with osciloskope)
but leds 18 and 19 lights and i don´t know why
thanks for help
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Toggle
cognew(@blikej,0)
repeat
DAT
org 0
blikej
mov dira,pin
mov Time, cnt
add Time, delay
loop xor outa,piny
waitcnt Time,delay
jmp #loop
Time res 1
delay long 80_000
pin long 00_0000_0000_0000_0000_0000_1111_1111
thanks for help
CON
PUB Toggle
cognew(@blikej,0)
repeat
DAT
org 0
blikej
mov dira,pin
mov Time, cnt
add Time, delay
loop xor outa,piny
waitcnt Time,delay
jmp #loop
Time res 1
delay long 80_000
all res have to be after declared longs.
EDIT - what is piny?
Enjoy!
yea you got right but the problem is that there is no signal also on osciloscope and i changed the delay and there was also nothing and strange is that lights leds 18 - 19
