Can we use an input that is not powered directly by the basic stamp?
Hello guys,
I'm a bit new to programming using parallax but I had a question. Can I use an input that is not powered directly by the parallax board (the 5V). I have a remote control from an old remote controled car where I can read 2V on the receiver when I press the left switch. I actually want to use this electric signal (0V when not pressed to 2V when pressed) as an input in order to start a program. The only problem is that this input is not directly powered by the board so I don't know where to connect the two wires that give me a difference of potential when I press the left button of my remote.
Thank you!
Thank you!
A 2 volt high may work, but you should test this again with both boards sharing the same ground. Sometimes, the actual voltage readings will be inaccurate when the two boards have no connection.
Do you mean I need to connect the ground of my remote control receiver to the vdd of the parallax?
Vdd is the regulated power supply for the Stamp and is essentially 5V. Vss is the ground for the Stamp. Vin is the unregulated supply voltage, either to the Stamp module or to the whole Stamp board. Vin can range from about 6V to at least 9V, sometimes higher depending on how it's regulated. The Stamp module has its own regulator if Vin is connected to the module. You never want to use Vin to power something or to connect to an I/O pin or other device if you don't know what you're doing. Connecting more than 5V to an I/O pin can damage or destroy the I/O pin and possibly the whole Stamp. The same is true about connecting a power source backwards to Vdd and Vss so the voltage on Vdd is negative with respect to Vss or if the voltage on an I/O pin is negative with respect to Vss.
Welcome to the forums!
When you say "Parallax Board", which one? Propeller or BS2? A Propeller pin has a 1.6 volt thresold to read a high signal.
I suspect you might be reading high of 2 volts on your reciever if you are using a general meter because of the averaging of PWM signals.
An inventory of the parts involved would help alot.
EDIT: Mike always types faster! And just noticed BS2 in message.
Its a BS2.
I suspect you would not destroy the whole BasicStamp if you made a big mistake. You would likely just damage the one i/o pin that is involved. I realize how worried you might be about this. But at some point, you have to learn to be careful to really enjoy using the BasicStamp.
Mike mentions using the LM339 to clean up the low voltage. it will work well and will provide protection to the BasicStamp. If you connect the 2 volts wrong to the LM339, that might suffer damage.. but nothing would happen to the BasicStamp.
Note, the input can go as high as +11V and as low as -1.1V without harm to the BS2.
Duane J
I'm sorry, I don't really understand your wiring diagram. Where should I connect the wires to vdd, vss? I'm new to all this and I guess I'm not ready to build this type of diagram without explanations. Also for me the output of the stamp is a signal that would command a servo. When you say "o-5v out" what are you meaning?
VDD is 5V on the BS2.
VSS is 0V or ground on the BS2 and on your RC equipment.
So:
"0V-5V OUT" in the diagram would go to the BS2 input pin which could be labeled "0V-5V IN".
Also:
Your RC equipment could be labeled "0V-2V OUT" and connected to "0V-2V IN" on the diagram.
Think:
OUT connects to IN.
BTW, almost any NPN transistor can be used in the circuit.
The 2N3904 is very generic and can even be gotten at Radio Shack.
Hope that helps.
Duane J
- whhere do I connect whats looking like a box with a cross on the top right?
- same for the one on the bottom right? Is it just indicating that I have to connect the ground of my remote to the ground of the board and nothing more?
Same for teh first questio, does it mean I have to connect the 2K and 3K resistors directly to the vdd?
In this case to VDD on the Stamp. That is correct. The ground, or VSS, between the Stamp and your equipment must be connected together. As well as one of the leads of the 2K resistor on the left. That is correct.
Duane J
