Coding data from basic stamp 2 to LCD display
Ok, so I ran a sample code that runs from the basic stamp 2 to an LCD screen and it worked. The code used the function DATA to display onto the LCD screen.
So for example, it had a lot of coding lines but then used, DATA "Hello world", and using that, the LCD displayed "Hello world".
Then I wanted to display data that I gathered from an ADC that was connected to a sensor. When I used the function DEBUG...., the correct information displayed on the PC. But then when I replace DEBUG with DATA, the program is giving an error saying that it was expecting a constant.
What do I need to do to display the data gathering from the ADC to display on the LCD screen?
The LCD that I am using is LCM1602A which I believe is similar to the HD44780
If the LCD has a serial interface, then SEROUT can be used with any version of the Stamp. If it has a parallel interface, then something else would be required such as the use of a version "P" Stamp as Mr. Albach mentioned.
BTW - DEBUG is just a special form of SEROUT that sends data to the Stamp editor debug window.
I will post the code a little later today
...any chance of a schematic also?
' ========================================================================= ' File...... Parallel_LCD_2X16.bs2 ' Purpose... Parallel LCD Display Demo ' Author.... Parallax, Inc. ' E-mail.... support@parallax.com ' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[ Program Description ]--------------------------------------------- ' This program demonstrates using a Hitachi-compatible Parallel LCD Display ' This code works with the BS2, BS2e and BS2sx ' -----[ I/O Definitions ]------------------------------------------------- E PIN 0 ' Enable Pin For LCD RW PIN 2 ' R/W Pin For LCD RS PIN 3 ' LCD Register Select ' 0 = Instruction, 1 = Text ' -----[ Variables ]------------------------------------------------------- char VAR Byte ' Character To Send To LCD inst VAR char ' Induction To Send To LCD index VAR Word ' Character Pointer temp VAR Byte ' Temp Variable ' -----[ EEPROM Data ]----------------------------------------------------- DATA "Hello, this is the LCD demo." ' Message To Send To LCD ' -----[ Initialization ]-------------------------------------------------- Initialize: LOW RW ' Set LCD To Write Mode OUTS = 00000000000000 ' Set All Output Low DIRS = 00000011111111 ' Set I/O Direction GOSUB Init_Lcd ' Initialize The LCD Display ' -----[ Program Code ]---------------------------------------------------- Main: FOR temp = 0 TO 27 ' 28 Characters IF temp = 15 THEN ' Check For End Of Line GOSUB Next_Line ' Jump To Next Line ENDIF READ temp, char ' Read Next Character From EEPROM GOSUB Send_Text ' Send Character To LCD Display NEXT END ' -----[ Subroutines ]----------------------------------------------------- Init_Lcd: PAUSE 200 OUTS = 110000 ' Reset The LCD PULSOUT E,1 ' Send Command Three Times PAUSE 10 PULSOUT E,1 PAUSE 10 PULSOUT E,1 PAUSE 10 OUTS = 100000 ' Set To 4-bit Operation PULSOUT E,1 Inst = 101000 ' Function Set (2-Line Mode) GOSUB Send_Inst Inst = 001110 ' Turn On Cursor GOSUB Send_Inst Inst = 000110 ' Set Auto-Increment GOSUB Send_Inst Inst = 000001 ' Clears LCD GOSUB Send_Inst Inst = 14 ' Set Cursor To Underline GOSUB Send_Inst RETURN Send_Inst: LOW RS ' Set Instruction Mode OUTB = Inst.HIGHNIB ' Send High Nibble PULSOUT E,1 OUTB = Inst.LOWNIB ' Send Low Nibble PULSOUT E,1 HIGH RS ' Set LCD Back To Text Mode RETURN Send_Text: OUTB = Char.HIGHNIB ' Send High Nibble PULSOUT E,1 OUTB = char.LOWNIB ' Send Low Nibble PULSOUT E,1 PAUSE 100 RETURN Next_Line: Inst = 128+64 ' Move Cursor To Line 2 GOSUB Send_Inst RETURNI have another code that helps get the data information that I need:
CS PIN 10 ' chip select DX PIN 11 ' data out CLK PIN 12 ' clock result VAR BYTE ' result of ADC conversion DO LOW CS ' enable CS SHIFTIN DX,CLK,MSBPOST,[result\9] ' read temperature and store in result HIGH CS ' disable CS DEBUG "Temp = ",DEC result*/$080,"F",CR ' display temp ($080 is scaling of 1/2 for Vref = 1.28v) PAUSE 1024 LOOPI tried adding this code above and it works but since i'm using DEBUG, it displays it on the PC. I assumed DATA would display it on the LCD screen but that is not the case. The program gives me an error that it is expecting a constant where DEC is in the DEBUG.
And I do not have a a schematic to go along with it, sorry about that.
The only thing DATA can do is store the constant or string of constants that follows it to the Stamp's EEPROM memory during program loading. It cannot write to the LCD, it just writes to EEPROM, nothing else.
When the above program is loaded into the Stamp, PBasic catches the DATA statement and places what follows into EEPROM storage. In your program under the heading '
[ EEPROM DATA ]
is the line DATA "Hello, this is the LCD demo." ' Message to send to LCD.
PBasic takes whatever is between the quotation marks and places it into EEPROM memory. Since a starting location was not specified the location defaulted to location 0 in EEPROM. Further down in your program in Main: you have a FOR loop which extracts one location at a time from EEPROM and places it into a variable called char. This is done by the statement READ temp, char. temp is used as an index variable that points to which location to READ from the EEPROM. The next statement GOSUB send_Text goes to a sub-routine called send_Text that takes the contents of the variable char and sends it to the LCD, then returns to Main: for more until the FOR loop is complete.
You cannot substitute the command DEBUG with DATA. All that will get you is an error.
In your code for the ADC you have defined a BYTE variable named result. Yet your program shifts in 9 bits from the ADC into result, which holds only 8 bits. Maybe this is what you want, I don't know.
In order to display the ADC result on the LCD you will have to copy result into char and then call the send_Text subroutine. But first you will have to scale result in order to display the correct number.
-=<[Chris]>=-
The 9-bit shift is required by the ADC0831 because it doesn't send out the data until the second clock pulse. The leading zero bit is simply shifted out of the result.
The scaling by 1/2 for a Vref of 1.28 is to put the LM34 data in range for the Temp display. Since Vref is 1.28, an input voltage from the LM34 of 1.27v will generate an ADC output of 255. Dividing by two yields 127 which is 127°F.
Look at Chris' examples. You'll need to pull each digit out of the result using the DIG operator and adjust it by ASCII "0" - zero - to make it show on the display.
