Hub Execution Model Thread (split from blog) - Page 18 — Parallax Forums
11618202122
    edited 2013-12-09 13:03
    Excellent!
    Re/ orphan register
    I think it would be a great choice for LR for gcc
    FYI,
    mov pc,#const9
    would be equivalent to jump (potentially freeing up a dual opcode)
    and if LR was at $1F1, then the cog-style jumps work, and the assembler is simpler - the return value is in a known location, no need to patch the JMPRET
    (just noted David proposed that call variant while I was typing this message, I think replacement is better)
    and yes,
    BIG #highbits
    mov pc,#const9 would work for hub jump, call ect, but cause a huge amount of hub memory to be wasted, thus the encoded instructions in post#2 of this thread.
    Roughly 1 in six instructions is a jump or call, so using two longs for it would waste 16% of the hub (which is why I made the tightly encoded jmp/call variants)
    You're right. That didn't occur to me. We would have to decide to cancel same-task instructions in the pipeline, or not. I think cancelling would be the safe bet, as some other cases would be indeterminate with multitasking enabled. So, a write to PC at $1F0 would cancel same-task instructions in the pipeline. Very cool!!! This would reduce table branches to 1 instruction! Works with hub execution, too. Awesome! I think I'll implement this right now, before I go any further. Now we've got one orphaned register in the last 16. Any quick idea for what we could use it for?
    edited 2013-12-09 13:04
    Quick question to everyone:
    What if we got rid of all the delayed branches?
    They are really only good for single-task programs, and in single-task programs, you can use REPS/REPD for zero-overhead looping. Of course, delayed branches give you more MIPS in single-task programs which branch a lot, if you are willing to slow down mentally and apply them properly. They also eat up a lot of instruction space and are a somewhat complex thing to document. Would they be missed?
    I'm just thinking that we've got hub and cog execution modes and the delayed branches really stink things up, in a way.
    edited 2013-12-09 13:05
    Good "CALL" :)
    David Betz wrote: »
    How about making that the LR register and adding a CALL instruction that stores its return address in $1f1? This would be an instruction like Bill's HCALL with a 16 bit immediate target address.
    edited 2013-12-09 13:07
    Are you suggesting the removal of CALL/RET or just that this is an alternative? I would recommend leaving CALL/RET because it allows one COG mode function to call another without worrying about clobbering the return address of the first one. It doesn't allow recursive calls to the same function but that is probably rare in COG code anyway.
    Great minds think alike? :-)
    edited 2013-12-09 13:11
    Excellent!
    Re/ orphan register
    FYI,
    mov pc,#const9
    and yes,
    BIG #highbits
    I've seen the LR issue discussed, but I haven't understood what it's about. Could you please explain what it does? David, what do you say?
    edited 2013-12-09 13:12
    They also eat up instruction space and are a somewhat complex thing to document and use. Would they be missed?
    They seem like a small thing to give up to gain opcode space, my vote is to get rid of them.
    C.W.
    edited 2013-12-09 13:15
    David Betz wrote: »
    Sounds like that may not actually be true.
    It's true enough, and I am going to assume you were not trying to say I was trying to mislead.
    David Betz wrote: »
    If you accept that I'm not suggesting removing any of the features that you think are important, you've already stated that you agree with the things I've suggested adding. If we can just get both sets of features we'll both be happy! :-)
    Of course, reality may get in the way of that but only Chip can say what we will end up with in the end.
    Now with this part, I agree!
  • SapiehaSapieha Posts: 2,964
    edited 2013-12-09 13:16
    Hi Chip.
    I think that will give code in OBX that are simpler to implement to multitasking.
    So in my opinion Remove it.
    edited 2013-12-09 13:18
    I would really, really hate that.
    I got some incredible performance in test code on the earlier FPGA code using it... which would now lose about 75% of the performance without delayed brances. It was a virtual machine.
    Performance would drop for my app by a factor of 3 or 4.
    You should ofcourse do what you think is best, however for my virtual machines, and processor emulations I was thinking of, I was able to use every single delay slot effectively getting 1 cycle branches.
    Unless of course
    mov pc,#xxxxx
    add pc,#xxxx
    sub pc,#xxxx
    call addr
    are single cycle, in which case definitely get rid of the delayed instructions!
    Hi,
    Sorry, strongly disagree. It slows down byte codes and processor emulations greatly.
    Sapieha wrote: »
    Hi Chip.
    edited 2013-12-09 13:21
    David Betz wrote: »
    Yep!
    edited 2013-12-09 13:27
    I'll try.
    Currently, for LMM, Eric uses a link register to hold the return address for subroutine calls, just like ARM chips, and early IBM mainframes.
    This is basically the same thing as storing the return address in the JMPRET at the end of a subroutine, but it is in a central, known location (You would need 4 for 4 tasks)
    This works extremely well for leaf subroutines (subroutines that do not call any other subroutines) as there is no need to push the return address on a hub stack.
    It does not work as well on on-leaf subroutines due to extra instructions (WRLONG LR, --SP / RDLONG LR,++SP) needed in non-leaf functions.
    Think of JMPRET that stores the return address in LR, not in the jump at the end of a subroutine.
    Sapieha wrote: »
    Hi Chip.
    I was just remembering that I had to get rid of all the delayed branches in the Spin2 interpreter because they wouldn't work if multitasking was enabled. I think I might feel lighter if I nuked them. It would simplify the overall programming picture for people and make code more mixable.
    edited 2013-12-09 13:31
    Oh Chip you are killing me!
    I have a hand-crafted VM I spent > 1 man month on that will slow down by about a factor of 2.5 without the delayed branches and calls.
    Btw - I don't need delayed branches/calls in multi-tasking mode at all. Does that help?
    edited 2013-12-09 13:35
    It looks like the delayed jump/call/ret instructions consume 23 opcodes.
    Is there a small most useful subset we could keep?
    C.W.
    edited 2013-12-09 13:39
    The idea is that a CALL_LR instruction (please find a better name!) will store its return address in the LR register. If the function being called is a leaf function then it will just JMP indirect through the LR register to return. If it is a non-leaf function, the LR register will be pushed on the stack along with any other registers that need to be preserved over the call to the nested function. This is exactly the way the current PropGCC code generator works. It saves an instruction over pushing the return address on an AUX stack and then having to pop it into a register in order to push it on a hub stack for non-leaf functions. I guess it doesn't really help over the AUX stack instructions for leaf functions.
    edited 2013-12-09 13:47
    I'd like to have a consistent policy about delayed branches, so I'll probably leave them alone. The thing is, DJNZ will work in hub mode, using an immediate #S as a sign-extended relative offset. That leaves DJNZD in there, too, working for hub mode. It just creates a huge proliferation of delayed-branch instructions as things grow.
    edited 2013-12-09 13:48
    David Betz wrote: »
    Thanks for all the explanations. I understand now. It's a stop-gap measure to avoid always playing with the stack.
    edited 2013-12-09 13:50
    ctwardell wrote: »
    C.W.
    I would assume that Bill was using them all, as they are all useful - but only in a single-task cog program. My interpreter is normally single-task, but because people could load code into the spare register space and enable multitasking, my interpreter had to be hardened to accommodate that possibility. Hence, I had to get rid of all delayed branches.
    I'm not sure what you mean by stop-gap but it does allow you to avoid a pop off the AUX stack for non-leaf functions. It also means you don't even have to touch the AUX memory in case you want to use it for something else.
    Thanks... maybe this will help?
    I really only need them in single tasking cog mode. It does not matter to me if delayed is not available when tasking or in hubexec mode.
    edited 2013-12-09 13:53
    I was using a good number of them, but not all.
    If it would help, I could make a list of the ones I can do without.
    edited 2013-12-09 13:56
    Got it. Hub code that used delayed branches would only be callable by single-tasking cogs, so no universally-callable hub code could even use delayed branches.
    edited 2013-12-09 13:58
    That list would be good to see. It might expose something useful.
  • jmgjmg Posts: 15,191
    edited 2013-12-09 14:00
    That's a good variant, but It could be long-term practical (it's a software management problem, not silicon) to support both under a "Spin2 interpreter " umbrella ?
    Users who want to pack code+threads into the Spin2 COG, can do so, or those who know they will not, can get a variant that is faster at the Spin2 (but lacks the thread-packing).
    edited 2013-12-09 14:02
    jmg wrote: »
    The speed difference might only 15%, so it's a lot of headache for a small benefit.
    edited 2013-12-09 14:05
    Good point.
    I'll find the latest instruction list, and make a list. It will take a few hours as I am actually visiting the forum while torturing a new pcb design (or is it torturing a new pcb design between visiting the forum?) LOL
    edited 2013-12-09 14:08
    I got significantly better than that... but it required a ton of tricks, and about a man-month of experiments to make optimal use out of the delay slots for my VM.
    FYI, it was that VM that made me ask for what became RDAUX reg,D/# as that will help me shave another cycle ... and even more saving from other uses of it.
    edited 2013-12-09 14:20
    Sounds like the classic Software moving target :)
    - but as this is a Software issue, and Spin2 is not in ROM, this is (relatively) easy to address over time. Just allow it to occur.
    Spin2 can potentially dynamically build (mentioned a while back & just software housekeeping) so it might even fold into that ?
    Users would tell the Spin2 builder what thread-code to include, and it then knows what Spin2 variants to craft with.
    edited 2013-12-09 14:22
    Putting the LR aside for a moment...
    If we used both $1F0 and $1F1 for PC, but made writes to $1F0 cancel pipelined instructions and writes to $1F1 not cancel, we could get both normal and delayed branches!
