Problem with basic forward and reverse of a servo motor. BS2p24
I have a BOE-BOT that had come with a BS2 . When I had programmed it originally I had no issues with the servo motors turning clockwise or counterclockwise. However, I have put a BS2p24 in replacement of the BS2. The code for pulsout 12, 500 does nothing different than pulsout 12, 1000. Is it a hardware problem? Thanks
Full forward=2.5 x 500 = 1250 (minimum value)
Stop=2.5 x 750 = 1875
Full reverse = 2.5 x 1000 = 2500
