OSH Stencils ????
TC
Hello all,
I was wondering if anyone has used OSH Stencils before? I like the prices they offer, but they seam a little cheep to me. $0.60USD a square inch?!?!
How was the quality, shipping, etc....
TC
TC
How bad could plastic stencils be if they are only getting use a couple of times?
A paint brush won't work at all. Solder paste is much thinker, like clay. Better than a paint brush would be a tooth pick. Even better is a syringe with a fine tip (the pressure helps prepare the paste).
Using plastic stencils for a 0.5 part might be a challenge. I tried it for a part with 0.45 and it didn't work very well at all. Solder paste would get stuck in the holes and miss pins entirely.
So it might be best just to use a toothpick. I dont want to spend an arm and a leg just for three boards that are about 1 square inch.
Perhaps the only thing I didn't like about the mylar stencil was the fact it was small and flexible vs larger and rigid for the stainless. The stainless was easier to hold in place while "squeegy"ing the paste on.
The cost savings for mylar for a small run of boards, especially if you aren't 100% finalized on the design far outweighs the inconvenience factor.
A LM4570 that is 2mm x 2mm (pads are 0.4 x 0.3)
File attached, it's NOT a zip file so rename .zip to .asc
TC,
Our edge quality and precision is higher than what you may be used to with Kapton and Mylar.
Give us a try, if you aren't happy, I'll make it right
-Brent
Thank you for the input. im still on the fence about needing a stencil. but I am afraid I will short out a few pins and have to start all over again.
Thats great! my part has the same pad dementions just more pins ( TI's RGY pacage )
Also, I could not rename your file.
OK!?!? was not expecting that.
I will try you guys out in a couple weeks (Christmas can be a killer), you seam to have a good product, and people are recommending you, and like I said "I like the price". You just cant tell what kind of a service someone has by there website.
Thank You
to rename a file extension, you need to be able to see them first.
1.Start Windows Explorer, you can do this by opening up any folder.
2.Click Organize.
3.Click Folder and search options.
4.Click the View tab.
5.Scroll down until you notice Hide extensions for known file types, un-check this line by clicking the check box.
6.Click OK
Depending on the complexity of the board, I use either 2 mil or 5 mil Polyimide and the highest resolution, 1200 dpi. You can print some very fine features with the 2 mil thickness, but your printing process must be dialed in so you aren't fighting insufficient solder issues to the point they cause opens.
I make my stencils on an Epilog Legend EXT 75 watt (same as Parallax) using GC PowerPlace (a paid upgrade of the free viewer GCPrevue) because it allows me to edit the gerber which in turn allows me to make apertures exactly the way I want. This is the next trick. When making stencils out of Polyimide or Mylar, your apertures should be modified to compensate for the material's weaknesses as well as for it's strengths. As an example, I use circular apertures for 0402 pads. I get cleaner paste release than if I used a rectangular pad because they are so small.
I will not use mylar for anything smaller than 0805 as it is just not worth the hassle. Pololu's mylar stencils are a prime example. I had a customer try ordering mylar stencils from them earlier this year for two separate PCBs and the results were unusable. I ended up cutting Polyimide stencils for both instead, even after Pololu re-cut one of them in efforts to address our concerns.
As for stenciling boards with paste, you can find a lot of youtube videos showing the DIY method. Solderpaste has the consistency of toothpaste and should be spread with a firm tool; I use a plastic putty knife. Use just enough pressure that you do not leave smear streaks of paste on top of the stencil. On this other thread by TonyP12, I list out what I use to paste PCBs at home using stainless steel stencils, but most of the process is the same for polyimide.
Ill have to try that once I get home after work.
That Is a lot of great info, Thank you for the advice.
I did it, now I found another problem, I dont have dip-trace, I use Eagle.
http://imgur.com/dIHKSOK,KQMr1QV
We have several companies using our service for rapid prototyping with high precision components.
If you aren't happy with the results, we'll make it right
-Brent
WOW Brent, that is impressive. on the Ohararp stencil you can see the inaccuracies between holes. I do have to say, you have my business after Christmas.
