PropGCC fcache and CMM
I'm having a curious problem with the fcache. I've run into this before, but for one reason or another wasn't able to make a post for it.
First, why do I assume the problem is the fcache? Because with -mfcache -mcmm the program does not work. With the other combinations (no-fcache/CMM, LMM/fcache) it works fine. The problematic code is not timing dependent or use any I/O.
Thy symptom of this problem is a loop that works if you have sufficient "stuff" inside of it (such as a printf or two), but fails when you don't have sufficient stuff. The fail mode is execution freezing. Other instances of this issue have resulted in gibberish on the pins.
I've tried several times to isolate this problem in a small program to no avail. So, I'm posting the full program here. It's the serial driver from libpropeller. The particular bit that fails is this:
libpropeller/printstream/printstream.h:
This loop works (ie, no freezing) with -mno-fcache, but freezes with -mfcache in CMM.
If I uncomment the printf the loop works (completes), even in cmm fcache mode.
I assume that my code is not the issue because of the change in behavior with the fcache switch. I'd expect that the code would operate identically with and without the switch.
I've attached a minimum working example. To run, make sure the symbolic links are good (or copy the files over). Then cd to the libpropeller/printstream/ folder. Run "make", then "./run_unit" (or load the .elf).
while(formatString[stringIndex] >= '0' and formatString[stringIndex] <= '9'){
paddingBuffer[paddingIndex++] = formatString[stringIndex];
// printf("+%c+", formatString[stringIndex]);
stringIndex++;
Does this happen with release_1_0 branch or the default?
I never call other functions from an fcache function.
The release_1_0 compiler doesn't support it AFAIK.
I've been dancing around this issue for a while (6 months or more?). My current testing is with a recent build (propellergcc-alpha_v1_9_0_2193).
Well, it's not calling anything (except optionally printf, which fixes the problem). And in any case if it's fcache'd then the compiler is doing it automatically: it's not an fcache marked function.
Ok, I've created issue #63: https://code.google.com/p/propgcc/issues/detail?id=63
Eric
Thanks for the bug report!
Anyway, you're right: I tried it with the most recent version of the code (propellergcc-alpha_v1_9_0_2245) and it still froze. I'm glad you found a fix!
On an unrelated note, the upgrade from 2193 to 2245 caused an increase in code size for two programs that I measured (same configuration both times):
So, a minimum of 300 bytes in this test.
As an interesting note, fcache increases the code size from 12944 to 13668 bytes, and changed the execution time from 0.285s to 0.279s. The code is some unit tests of a serial function.
