Load EEPROM & run problem
I programed it with 'Load EEPROM & Run', it seems like it completed with out hitch, but when I go to battery power and start back up again, power setting is on #2, the program is not starting. Of course this is the ActivityBot with the li-ion battery power pack, and the batteries are fully charged(7.7V). Code Size 24,660 bytes (28,688 total).Project Directory: E:/PropGCC/SimpleBot/SimpleBot/
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2162)
propeller-elf-gcc.exe -I . -L . -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/ActivityBot 2013-10-31/libabdrive -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/ActivityBot 2013-10-31/libabdrive/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/libsonyremote -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/libsonyremote/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Text Devices/libsimpletext -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Text Devices/libsimpletext/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Convert/libadcDCpropab -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Convert/libadcDCpropab/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Text Devices/libfdserial -L C:/Users/Ray/Documents/SimpleIDE/Learn/Simple Libraries/Text Devices/libfdserial/cmm/ -o cmm/SimpleBot.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 SimpleBot.c -lm -labdrive -lsonyremote -lsimpletext -ladcDCpropab -lping -lsimpletools -lsimplei2c -lfdserial -lm -labdrive -lsonyremote -lsimpletext -ladcDCpropab -lping -lsimpletools -lsimplei2c -lm -labdrive -lsonyremote -lsimpletext -ladcDCpropab -lping -lsimpletools -lm -labdrive -lsonyremote -lsimpletext -ladcDCpropab -lping -lm -labdrive -lsonyremote -lsimpletext -ladcDCpropab -lm -labdrive -lsonyremote -lsimpletext -lm -labdrive -lsonyremote -lm -labdrive -lm
SimpleBot.c: In function 'get_Time':
SimpleBot.c:279:3: warning: return makes integer from pointer without a cast [enabled by default]
SimpleBot.c: In function 'get_Date':
SimpleBot.c:291:3: warning: return makes integer from pointer without a cast [enabled by default]
SimpleBot.c: In function 'get_Volts':
SimpleBot.c:304:3: warning: return makes integer from pointer without a cast [enabled by default]
propeller-load -s cmm/SimpleBot.elf
Patching __cfg_sdspi_config1 with 00000000
Patching __cfg_sdspi_config2 with 00000000
propeller-elf-objdump -h cmm/SimpleBot.elf
Done. Build Succeeded!
propeller-load.exe -Dreset=dtr -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b ACTIVITYBOARD cmm/SimpleBot.elf -e -r -p COM11
Propeller Version 1 on COM11
Patching __cfg_sdspi_config1 with 18161701
Loading cmm/SimpleBot.elf to EEPROM via hub memory
24660 bytes sent
Verifying RAM ...
OK
Programming EEPROM ...
OK
Verifying EEPROM ...
OK
I am also wondering if SimpleIDE could have just a 'Load EEPROM' setting, sometimes it is necessary to just load the EEPROM without having it start up a program.
Ray
What happens if you use a simple LED blinker program?
/** * This is the main blinky program file. */ #include "simpletools.h" int main(void) { int pin = 27; // Activity Bot Amber LED near breadboard. high(pin); while(1) { pause(250); toggle(pin); } return 0; }Ray
If it doesn't work with a simple blinker, there is no hope of it working with anything else.
Did you try the Activity board power test? Some Activity boards had a little power trouble.
I don't have time to work on an EEPROM test today. The turkey needs me.
I found a "Supply Noise and Range Test" program, the p26/p27 LEDs stayed illuminated, so I guess the power supply is OK. I tried blanking out the EEPROM, meaning I just loaded a blank program to EEPROM that seemed to work, cleaning out the blinker. I then re-loaded the blinker, and started it up on battery power, and nothing. So, this is the second Activity Board that has gone bad, starting to wonder about the quality of these boards. I guess I can still use it as long as I do not use the EEPROM. Anybody have any other ideas as to what or how I could check to see what the real problem is?
Ray
Also, does the EEPROM program run when under USB power? IOW, after loading and pressing the reset button, does the program work okay?
Ray
Ray
Anyway, I suspect your power source might be the problem. Have you got any other 6V-9V DC source other than the Li-ion batteries that you could try?
With the li-ion battery source plugged in, and NO USB plugged -
move power switch to 1, green LED turns on
move power switch to 2, both LEDs are on, no blinker program working.
With 9V wall-wart plugged in, and NO USB plugged -
move power switch to 1, NO green LED
move power switch to 2, both LEDs are on, the blinker program is working.
move power switch back to 1, green LED stays ON
move power switch back to 0, LEDs are off.
Something is definitely gone bad. Well I guess I have to put my ActivityBot in a box, and move on to other things.
Ray
Just out of curiosity, what happens in the 9V wall wart scenario if you jumper a 100-ohm resistor between +5V and Gnd? Then between +3.3V and Gnd?
Ray
Ray
If it works on a wall wart, but not the LI-ON, maybe there is an issue with the battery's current capacity.
I use Duracell Alkaline AA.
Ray
But, I am still done with the xxxBOT stuff, it is now packed in a box. I will also be very apprehensive as to what and how I use the Activity Board, maybe later today I will try to test the components on the board, and maybe my new project will be a diagnostic program for testing the board. Or maybe I should just lay down and read a good book...
Ray
