What is this error code?
Back in Sept I created a program, ABdiag.side which was running without any problems. I just tried to run this program with 0-9-45, and it comes up with the error, not sure what I would have to change in order for it too compile. Any ideas?propeller-elf-gcc.exe: error: CreateProcess: No such file or directory
Done. Build Failed!
Ray
Add your code to the thread so folks can help you...
dgately
Try uninstalling and then reinstalling SimpleIDE.
===Jac
Can you build anything?
Please post all of the build output.
Here goes.
Ray
Don't ask how that happened.
I have a fix for that. Will send you a PM.
Even with most horribly convoluted and lengthy error messages from templated code in C++ I have never seen such an error from a compiler.
Well done!
Hear! Hear! [Golf clap]
Click error or warning messages above to debug.
