Asking for Gripper Feedback Advice
ajward
I'm in the process of replacing Wally's defective ankle and the new shiny thing arrived:
Just wondering is anyone has devised any kind of feedback for this kind of gripper? So you don't crush delicate things or stall the servo.
Appreciate any guidance!
Amanda
Amanda
Since you probably want your gripper to open and close fairly rapidly, that means a low-ish gear ratio, which means fast acting but low torque. So just from a practical angle the gripper likely won't crush most non-living things. Select a servo with the appropriate torque. That will also mitigate most any gear stripping.
You could just add a few series diodes to drop the voltage going to the gripper servo. I prefer diodes to a big power resistor, but one of those could be used too.
Here's Phil's tutorial.
Amanda
