problem connecting two sub2ser
the drivers are installed by the < Install-Parallax-USB-Drivers-v2.08.24 .exe> app
and there is no auto driver recognition with the adapter and i have tried two install the drive visa control panel, flags on the basic stamp editor that there is another app using the line which is false.
Any help?
Also when I uninstall the driver for the adapter and do a new hard were search becomes a unid device.
Any help?
did a manual driver install just two get a driver two install.
the driver did install but now i cant access the adapter from the program
the respoine is the adpter is busy / in use witch it's not
I am assuming you are referring to the USB2SER development tool. If you are trying to connect these to a BASIC Stamp Module it will not work as the BASIC Stamp Module accepts inverted RS-232 level signals while the USB2SER provides non-inverted line-level signals.
