Simple (I hope) problem with FloatString
I don't know what I have changed.
This is about as simple of a floating point test program as I can come up with:
It has worked in the past. I've seen it. It showed me "2.5" as pretty as you please, and I called it good... and then when I tried to build something useful using it, it stopped working there and also stopped working here. Now it gets hung up at the FloatToString and never shows a value there nor gets to the "Ending" text.
I've replaced my copy of FloatString with the v1.2 from http://obex.parallax.com/object/236 and it didn't help. I am using Float32 in the FloatString instead of FloatMath. I'm sure it's something simple but I've been bouncing my head off this for a couple of days and it's time to ask folks who know things. Can any of y'all point me in the right direction?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
pst : "Parallax Serial Terminal"
f : "Float32"
fs : "FloatString"
PUB test3 | fa, fb
f.Start
pst.Start(115_200)
pst.Str(String("Starting."))
pst.NewLine
fa := f.FFloat(5)
fb := f.FDiv(fa, 2.0)
pst.Str(fs.FloatToString(fb))
pst.NewLine
pst.Str(String("Ending."))
Are you starting this object (on demand)? Since FloatString itself doesn't feature a start method it's the most likely cause.
Thank you for taking a look at this.
ifnot started started := F.startstarted is a global variable.Thank you, kuroneko. I don't know why it worked for me before and then stopped... but now it works again and I appreciate it!
