HMC5883L i2c not working with PIC16F886
Hi!
I'm trying to use HMC5883L module with PIC16F886, Vdd=5V. I've written a simple programa to send data to the module. But it doen't work.
If I use the PIC without the module and I put two 10K pullup resistors at SDA and SCL lines, the program sends data to the i2c bus, but if a plug in the module and remove the 10K pull-up (the module has a 2k2 pull up at SCL and a 4K7 pullup at SDA) then both SCL and SDA remain high, and the PIC is not able to send the START.
If tried to plug the module to the pic with bot 10K pull-up resistors buth then when I turn on the i2c module on the PIC, SCL goes down and it remains down, so the PIC is not able to send the start either.
So i guess is problem with pull-up values, but i don't know what is the problem. Any help please?
regards
regards
I'm confused because you say in one case the SDA and SCL stay high, but in the second case SCL stays low. What is the difference in your setup between these two cases ?
It sounds like you are saying WITH the 10K pullup SCL goes low and stays low, and WITHOUT the 10K pullup both lines say high. That makes no sense...
It also could be that there is something wrong with the module.
Bean
P.S. You do have a common ground connection ???
If I connect the pic to the module without pull-up resistors (which is what is supposed to be the correct way because the module have built-in pullups) both libes remanin high and the pic is not able to send a START.
And with the module and two 10K pull-up SCL goes low in the same moment I enable the pic i2c module (when SCL is configured as open drain) and SDA remains high.
Connecting 10K resistors as I'm doing put them in parallel with the built in resistors so I have
SDA 10K || 4k7 = 3K2
SCL 2K2 || 10K = 1K8
I'm going to try different resistor values for SCL pull-up but I found it annoying.
regards
