P8X32A with SD shield
Hi, I am new to the forum and certainly new to electronics of this depth. Trying to learn C language and probably way over my head but I'm trying. I bought the above mentioned prop board and also have a seed SD shield that I want to try and use together if its possible. I need to be able to data log (record) from devices that use serial data in a log chain fashion. I also have the Arduino UNO setup that I purchased , not knowing which one I would be better off using for this project. Also I apologize if I posted this question in the wrong section. Just let me know. I have thick skin. lol. I appreciate in advance anyone who might have the patients to work with me on it. I am going to try and post a link to the device that I want to data log from. Its a technical pdf document from their site that lays out the protocol that they use. -Jim www.innovatemotorsports.com/resources/serial-protocol.php Also, I have tons of resistors, caps and misc stuff. I will buy anything else I need that I may not have. I also have IDA pro and some other programs that may help me out. All I need is some help and hopefully learn something.
Still, it's not hard. After you've received the 16-byte packet could make a simple method like this to fix the Big Endedness
Since you are just starting out, there is a tool set that is much simpler (and in my opinion) more fun than C, this alternative is Propforth,
There is a logger that you can simply load, and the only extra parts you need are an SD adaptor, a couple resistors, and some wires.
http://code.google.com/p/propforth/wiki/Logger1Simple
It can log at least one record per second, and provides unique time stamps for longer than you will live. Give it a try, you can ask as many questions as you need.
So If you can an SD adapter, you can add an SD to the quickstart per
http://code.google.com/p/propforth/wiki/SDsetupREVISITED
There are several examples of the logger, it can do very accurate time stamps, and it the clock will probably never roll over. Mine has been running to two months and has gained 9 seconds, but I didn't both setting the drift as its better than most of the regualr clocks in my house as it is.
You should use a bread board to get started, don't solder too much until you are sure the circuits are correct. Just make jumpers out of 22 gauge solid core hook up wire.
If you decide to try the forth stuff, just post all your questions. Folks will usually answer even if I'm not available. If you use the spin stuff, there are tons of folks here that will help you. The C stuff is still a little rough, I would hold off on that for a lit, Idon't know if its suitable for beginners at this time. The forth stuff is easiest and most fun if you ask me, but other folks will have other opinions.
