Score counter from 0-3
Hello everyone,
I am trying to write a subroutine for a game that will keep score (from 0-3) every time port 1 is switched to high, however I am missing something because only a zero is shown on my 7-segment display when port 1 goes high and does not change after subsequent highs to port 1. Can anyone help please. Thanks
' {$STAMP BS2}
' {$PBASIC 2.5}
'========DIR===========================================
OUTH = %00000000 ' Clear LED display
DIRH = %11111111 ' Set pins 8-15 to outputs
'=======VARIABLES======================================
index VAR Nib
score VAR Nib
DO
FOR index = 1 TO 3
IF IN1 = 1 THEN
PAUSE 10
score = 0
score = score + 1
LOOKDOWN score, [ 3, 2, 1], index
LOOKUP index, [ %10000100, %11010011, %11100111], OUTH
ENDIF
NEXT
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
index VAR Nib
score VAR Nib
DO
FOR index = 1 TO 3
IF IN1 = 1 THEN
PAUSE 10
score = 0
score = score + 1
ENDIF
NEXT
LOOP
I removed the for/next as you suggested and it worked much better. This program is for a game I am making for my son. When I removed the for/next, the 7-segment display went blank, however the servos now rotate as they should. The intent of this program is that when port 1 is high, a servo rotates, a buzzer comes on, and there is a score shown on the display, which ends the game when the score equals 3. I'm not sure how to have the score display and increment every time port 1 goes high. The code for subroutine Target2 will be the same as Target1 subroutine, which I am working on now. Thanks!
' {$STAMP BS2}
' {$PBASIC 2.5}
OUTH = %00000000
DIRH = %11111111
SRVOcounter VAR Word
SCORcounter VAR Bit
index VAR Bit
'=======MAIN===========================================
MAIN:
DO
IF IN1 = 1 THEN
FREQOUT 6, 140, 4200
GOSUB TARGET1
ELSEIF IN2 = 1 THEN
GOSUB TARGET2
ENDIF
LOOP
'========SUBROUTINES====================================
Target1:
SCORcounter = 0
IF IN1 = 1 THEN
PAUSE 10
SCORcounter = SCORcounter + 1
LOOKDOWN SCORcounter, [ 3, 2, 1], index
LOOKUP index, [ %10000100, %11010011, %11010110], OUTH
ENDIF
FOR SRVOcounter = 1 TO 25
PULSOUT 14,1100 'Servo rotates DOWN"
PAUSE 20
NEXT
PULSOUT 14, 660 'Servo rotates UP"
PAUSE 20
LOW 1
NEXT
PAUSE 20
RETURN
Target2:
DEBUG "DEBUG Target 2", CR 'Target 1 hit"
PULSOUT 15,1100 'Servo rotates DOWN"
PAUSE 20
NEXT
PULSOUT 15, 660 'Servo rotates UP"
PAUSE 20
LOW 2
NEXT
PAUSE 20
RETURN
I'm not a BS2 user so the syntax may not be correct but the logic is.
'=======START===========================================
START:
SCORcounter = 0
MAIN:
DO
IF IN1 = 1 THEN
GOSUB TARGET1
ELSEIF IN2 = 1 THEN
GOSUB TARGET2
ENDIF
IF SCORcounter < 3 THEN
LOOP
ELSE GOTO START
Hi kwinn. Yes, the SCORcounter = 0 is located in the "Variables" before the MAIN. I only have a "1" showing up and it does not change each time there is a high on IN1. I just can't figure it out. Thanks
' {$STAMP BS2}
' {$PBASIC 2.5}
OUTH = %00000000
DIRH = %11111111
SCORcounter VAR Bit
SCORcounter = 0
index VAR Bit
MAIN:
DO
IF IN1 = 1 THEN
GOSUB TARGET1
ELSEIF IN2 = 1 THEN
GOSUB TARGET2
ENDIF
IF SCORcounter
GOTO MAIN
ENDIF
LOOP
Target1:
PAUSE 20
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
RETURN
Target2:
PAUSE 20
PAUSE 20
NEXT
PAUSE 20
NEXT
PAUSE 20
RETURN
RETURN
' {$STAMP BS2} ' {$PBASIC 2.5} '=======IR=========================================== OUTH = %00000000 DIRH = %11111111 '=======VARIABLES====================================== SRVOcounter VAR Word SCORcounter VAR Bit index VAR Bit '=======MAIN=========================================== MAIN: DO SCORcounter = 0 DO IF IN1 = 1 THEN FREQOUT 6, 140, 4200 GOSUB TARGET1 ELSEIF IN2 = 1 THEN FREQOUT 6, 140, 4200 GOSUB TARGET2 ENDIF LOOP LOOP '========SUBROUTINES==================================== Target1: IF IN1 = 1 THEN PAUSE 10 SCORcounter = SCORcounter + 1 LOOKDOWN SCORcounter, [ 3, 2, 1], index LOOKUP index, [ %10000100, %11010011, %11010110], OUTH ENDIF FOR SRVOcounter = 1 TO 25 PULSOUT 14,1100 'Servo rotates DOWN" PAUSE 20 NEXT FOR SRVOcounter = 1 TO 25 PULSOUT 14, 660 'Servo rotates UP" PAUSE 20 LOW 1 NEXT PAUSE 20 RETURN Target2: DEBUG "DEBUG Target 2", CR 'Target 1 hit" FOR SRVOcounter = 1 TO 25 PULSOUT 15,1100 'Servo rotates DOWN" PAUSE 20 NEXT FOR SRVOcounter = 1 TO 25 PULSOUT 15, 660 'Servo rotates UP" PAUSE 20 LOW 2 NEXT PAUSE 20 RETURNPS - If it still does not work try posting your question in the Basic Stamp forum.
skylight, sounded like a good suggestion but did not work. I will keep trying to figure this one out. Thanks again
When I'm having trouble such as you are having,
I write a very super simple program to test only the function that I feel is giving trouble.
I would try something like this:
Keep the IR, and VARIABLES as is.
Then only write the simple program something like what I've written below.
MAIN:
SCORcounter = 0
GOTO Test
Test:
LOOKDOWN SCORcounter, [3,2,1], index
LOOKUP index, [%10000100,%11010011,%11010110], OUTH
SCORcounter = SCORcounter +1
PAUSE 1000
If SCORcounter <4 GOTO Test
Debug " I'm Done", cr
END
If this simple code is correct your display should start in the off condition
Then cycle through the numbers 1 to 3
When you get a very super simple program section working correctly, you will understand
what is and is not working.
I could not actually try this code as my BS2 is tied up at the moment.
This is the strategy I always use when I'm not understand something.
I hope this helps you out in some manner.
