Vibra Tab Amplification
This is a follow up on an earlier question.
Any idea how I can amplify the signal from the Tab to turn on a 5V reed relay? I am trying to have 16 TABs to be ready by the 2 chained 74HC165 to a BS2. Since I can't read the TAB directly from the 165, I thought using a simple relay to emulate a switch.
I tried various simple charge amplifier switch (such as the 2222A or the TIP120) without any luck.
Any ideas?
many thanks in advance.
Any ideas?
I must be not clear on how the 165 works. My understanding is that its input pins need to be pulled to ground. When reading the 165, I get 11111111. When I pull any of the inputs to to ground (with a switch), I get 00000001 for example. How will your circuit achieve that? it is ideal that I don't use a relay so you solution is very appealing.
Please clarify.
Al
When the circuit above is triggered, the voltage will rise to 2.83V which is above the HIGH level voltage threshold of 2.4V for the 74HC165. Because of the capacitor, the above circuit will 'hold' that voltage long enough for a reading to be taken via the 74HC165.
Try it first with a single channel or two and see if it responds the way you like. If the 2.83V is not high enough, then there are also ways to raise that.
many thanks again,
Al
I may sound like a broken record, but try an SCR. You'll like the results. They're magic.
Reference Circuit was derived from the famous ZN414 transistor
http://en.wikipedia.org/wiki/ZN414
Two transistor derivative of the ZN414
http://www.zen22142.zen.co.uk/Circuits/rf/amrec.html
"I also tried this simplistic circuit and it doesn't work. any idea why?" - It isn't properly biased to the high impedance nature of the Vibra tab.
An SCR latching circuit is perfectly fine also, but I read the post as you wanting Amplification so I provided an amplifier. SCR's can be tricky also ... to turn off properly. Turning them on is usually very easy, but they often turn on hard and saturate the transistors making them tricky to turn off. In either case, a relay is not necessary for what you want to do.
The winner gets bragging rights for fewest number of components and most cost effective solution
Stuff and nonsense. By my rules, one can use SCRs but no transistors.
Light activated SCRs (LASCRs) used to be easy to get and are also magic. Not sure you can even buy them anymore! http://www.circuitstoday.com/lascr-light-activated-scr
http://www.bristolwatch.com/ele/lascr.htm
I'm taking my SCRs and going home!
Sheesh!
The Tab had to be bent visibly in order to get the voltage over the threshold of 2.4V. So, I tried using a small Piezo buzzer from Radio Shack and that works even with blowing on it. So, I now got it!
Many thanks again Beau and the entire team. I am sorry to have started a 'war' of circuit design but it is wonderful to see Parallax team so engaged. I toyed with switching to Adruino at some point with the lure of speed and IOs but you guys convinced me to stay with Parallax for excellent product and amazing support.
Al
One thing you can do to raise the voltage potential that hinted to in an earlier post, is to add a resistor the the NPN emitter leg going to Ground. I would try a 470 Ohm to start out with and go from there with a little experimentation.
