Stability
Hello,
I made up a pressure sensor LED bar display using a BS2 and a fliexiforce resistive sensor. There is a 10 M ohm resistor in parallel with the flexiforce sensor and is setup usin an RCTime circuit. I am using an AC adapter. The main circuit with the RC timer is on a BS2 protoboard, the signals to drive the LED bar display are sent over a ribbon cable to another protoboard with the display drivers and LEDs. The program is pretty basic and is below.
The problem is when I have a laptop connected to it everything works just fine, when I try this without the laptop things become unstable. i.e. the LEDs will sometime light randomly.
Any suggests would be of great help,
Larry
' {$STAMP BS2}
' {$PBASIC 2.5}
'Test pressure sensor
' Read pressure sensor in RC-time circuit using RCTIME command
'Pin 0 = IN0 - Bit 0 on thumbwheel
'Pin 1 = IN1 - Bit 1 on thumbwheel
'Pin 2 = IN2 - Bit 2 on thumbwheel
'Pin 3 = RC Timer
'Pin 4 -> 16 Output LEDs
' 50 GR = 0 OZ = 3695
' 60 GR = 0.4 OZ = 3463
' 100 GR = 1.8 OZ = 2362
' 115 GR = 2.25 OZ = 1630
' 135 GR = 3.0 OZ = 1274
' 175 GR = 4.5 OZ = 828
TSELECT VAR Byte
time VAR Word
offset VAR Word
offset1 VAR Word
I VAR Nib
TS0 VAR Word
TS1 VAR Word
TS2 VAR Word
TS3 VAR Word
TS4 VAR Word
PP VAR Word
Mx VAR Nib
MV VAR Word
TS0 = 3463
TS1 = 2362
TS2 = 1630
TS3 = 1274
TS4 = 1000
' Set Max Pressure level (max is 1)
MP VAR Word
' LED output pins
LOW 4
LOW 5
LOW 6
LOW 7
LOW 8
LOW 9
LOW 10
LOW 11
LOW 12
LOW 13
LOW 14
LOW 15
offset1 = 0
PAUSE 1000
HIGH 3
' Turn off LEDs
LOW 4
LOW 5
LOW 6
LOW 7
LOW 8
LOW 9
LOW 10
LOW 11
LOW 12
LOW 13
LOW 14
LOW 15
' Test LEDs
PAUSE 200
HIGH 4
PAUSE 200
LOW 4
HIGH 5
PAUSE 200
LOW 5
HIGH 6
PAUSE 200
LOW 6
PAUSE 100
HIGH 7
PAUSE 200
LOW 7
HIGH 8
PAUSE 200
LOW 8
HIGH 9
PAUSE 200
LOW 9
HIGH 10
PAUSE 200
LOW 10
HIGH 11
PAUSE 200
LOW 11
HIGH 12
PAUSE 200
LOW 12
HIGH 13
PAUSE 200
LOW 13
HIGH 14
PAUSE 200
LOW 14
HIGH 15
PAUSE 400
' Calibrate - calculate offset
offset1 = 0
FOR I = 1 TO 5
HIGH 3
RCTIME 3, 1, offset
PAUSE 1000
offset1 = offset + offset1
DEBUG HOME, "time = ", DEC5 time
DEBUG " offset1 = ", DEC5 offset1
DEBUG " MP = ", DEC5 MP
DEBUG " I = ", DEC1 I
DEBUG CRSRDN
DEBUG CR
NEXT
offset = 500 + offset1/5
DEBUG " offset = ", DEC5 offset
' Read thumbwheel
IF IN0 = 0 AND IN1 = 0 AND IN2 = 0 THEN Mx = 1: MV = offset - 2700
IF IN0 = 1 AND IN1 = 0 AND IN2 = 0 THEN Mx = 1: MV = offset - 1800
IF IN0 = 0 AND IN1 = 1 AND IN2 = 0 THEN Mx = 1: MV = offset - 950
IF IN0 = 1 AND IN1 = 1 AND IN2 = 0 THEN Mx = 1: MV = offset - 750
IF IN0 = 0 AND IN1 = 0 AND IN2 = 1 THEN Mx = 1: MV = offset - 580
PP = offset
LOW 15
HIGH 14
PAUSE 200
LOW 14
HIGH 13
PAUSE 200
LOW 13
HIGH 12
PAUSE 200
LOW 12
HIGH 11
PAUSE 200
LOW 11
HIGH 10
PAUSE 200
LOW 10
HIGH 9
PAUSE 200
LOW 9
HIGH 8
PAUSE 200
LOW 8
HIGH 7
PAUSE 200
LOW 7
HIGH 6
PAUSE 200
LOW 6
HIGH 5
PAUSE 200
LOW 5
HIGH 4
PAUSE 200
LOW 4
DO
HIGH 3
PAUSE 5
RCTIME 3, 1, time
DO WHILE time = 0
RCTIME 3,1, time
LOOP
DEBUG CRSRY, 1
DEBUG CR
DEBUG "time = ", DEC5 time
DEBUG " Offset = ", DEC5 offset
DEBUG " MV = ", DEC5 MV
DEBUG " PP = ", DEC5 PP
DEBUG " Mx = ", DEC5 Mx
IF time > PP THEN time = offset
IF time > (PP - (MV*1)/(Mx*12)) THEN HIGH 4 ELSE LOW 4
IF time =< (PP - (MV*2)/(Mx*12)) THEN HIGH 5 ELSE LOW 5
IF time =< (PP - (MV*3)/(Mx*12)) THEN HIGH 6 ELSE LOW 6
IF time =< (PP - (MV*4)/(Mx*12)) THEN HIGH 7 ELSE LOW 7
IF time =< (PP - (MV*5)/(Mx*12)) THEN HIGH 8 ELSE LOW 8
IF time =< (PP - (MV*6)/(Mx*12)) THEN HIGH 9 ELSE LOW 9
IF time =< (PP - (MV*7)/(Mx*12)) THEN HIGH 10 ELSE LOW 10
IF time =< (PP - (MV*8)/(Mx*12)) THEN HIGH 11 ELSE LOW 11
IF time =< (PP - (MV*9)/(Mx*12)) THEN HIGH 12 ELSE LOW 12
IF time =< (PP - (MV*10)/(Mx*12)) THEN HIGH 13 ELSE LOW 13
IF time =< (PP - (MV*11)/(Mx*12)) THEN HIGH 14 ELSE LOW 14
IF time =< (PP - MV) THEN HIGH 15 ELSE LOW 15
LOOP
Larry
' {$STAMP BS2}
' {$PBASIC 2.5}
'Pin 3 = RC Timer
TSELECT VAR Byte
time VAR Word
offset VAR Word
offset1 VAR Word
I VAR Nib
TS0 VAR Word
TS1 VAR Word
TS2 VAR Word
TS3 VAR Word
TS4 VAR Word
PP VAR Word
Mx VAR Nib
MV VAR Word
TS0 = 3463
TS1 = 2362
TS2 = 1630
TS3 = 1274
TS4 = 1000
MP VAR Word
' LED output pins
LOW 4
LOW 5
LOW 6
LOW 7
LOW 8
LOW 9
LOW 10
LOW 11
LOW 12
LOW 13
LOW 14
LOW 15
offset1 = 0
PAUSE 1000
HIGH 3
' Turn off LEDs
LOW 4
LOW 5
LOW 6
LOW 7
LOW 8
LOW 9
LOW 10
LOW 11
LOW 12
LOW 13
LOW 14
LOW 15
' Test LEDs
PAUSE 200
HIGH 4
PAUSE 200
LOW 4
HIGH 5
PAUSE 200
LOW 5
HIGH 6
PAUSE 200
LOW 6
PAUSE 100
HIGH 7
PAUSE 200
LOW 7
HIGH 8
PAUSE 200
LOW 8
HIGH 9
PAUSE 200
LOW 9
HIGH 10
PAUSE 200
LOW 10
HIGH 11
PAUSE 200
LOW 11
HIGH 12
PAUSE 200
LOW 12
HIGH 13
PAUSE 200
LOW 13
HIGH 14
PAUSE 200
LOW 14
HIGH 15
PAUSE 400
offset1 = 0
FOR I = 1 TO 5
HIGH 3
RCTIME 3, 1, offset
PAUSE 1000
DEBUG CRSRDN
DEBUG CR
NEXT
' Read thumbwheel
PP = offset
LOW 15
HIGH 14
PAUSE 200
LOW 14
HIGH 13
PAUSE 200
LOW 13
HIGH 12
PAUSE 200
LOW 12
HIGH 11
PAUSE 200
LOW 11
HIGH 10
PAUSE 200
LOW 10
HIGH 9
PAUSE 200
LOW 9
HIGH 8
PAUSE 200
LOW 8
HIGH 7
PAUSE 200
LOW 7
HIGH 6
PAUSE 200
LOW 6
HIGH 5
PAUSE 200
LOW 5
HIGH 4
PAUSE 200
LOW 4
DO
HIGH 3
PAUSE 5
RCTIME 3, 1, time
DO WHILE time = 0
RCTIME 3,1, time
LOOP
DEBUG CRSRY, 1
DEBUG CR
LOOP
' {$PBASIC 2.5}
'Pin 3 = RC Timer
'Weight reference grams = oz = RCTime
' Variables
time VAR Word
offset VAR Word
offset1 VAR Word
I VAR Nib
TS0 VAR Word
TS1 VAR Word
TS2 VAR Word
TS3 VAR Word
TS4 VAR Word
Mx VAR Nib
MV VAR Word
MP VAR Word
' Initialize variables
TS0 = 3463
TS1 = 2362
TS2 = 1630
TS3 = 1274
TS4 = 1000
offset1 = 0
time = 0
' LED output pins set LEDs Off
LOW 4
LOW 5
LOW 6
LOW 7
LOW 8
LOW 9
LOW 10
LOW 11
LOW 12
LOW 13
LOW 14
LOW 15
PAUSE 1000
' Set RCTIME Initial state
HIGH 3
' Test LEDs seqquence up, Calibrate, then down
PAUSE 200
HIGH 4
PAUSE 200
LOW 4
HIGH 5
PAUSE 200
LOW 5
HIGH 6
PAUSE 200
LOW 6
PAUSE 100
HIGH 7
PAUSE 200
LOW 7
HIGH 8
PAUSE 200
LOW 8
HIGH 9
PAUSE 200
LOW 9
HIGH 10
PAUSE 200
LOW 10
HIGH 11
PAUSE 200
LOW 11
HIGH 12
PAUSE 200
LOW 12
HIGH 13
PAUSE 200
LOW 13
HIGH 14
PAUSE 200
LOW 14
HIGH 15
PAUSE 400
FOR I = 1 TO 5
HIGH 3
RCTIME 3, 1, offset
PAUSE 1000
DEBUG CRSRDN
DEBUG CR
NEXT
' Average and fudge factor offset
' Read thumbwheel
' Test LEDs sequence down
LOW 15
HIGH 14
PAUSE 200
LOW 14
HIGH 13
PAUSE 200
LOW 13
HIGH 12
PAUSE 200
LOW 12
HIGH 11
PAUSE 200
LOW 11
HIGH 10
PAUSE 200
LOW 10
HIGH 9
PAUSE 200
LOW 9
HIGH 8
PAUSE 200
LOW 8
HIGH 7
PAUSE 200
LOW 7
HIGH 6
PAUSE 200
LOW 6
HIGH 5
PAUSE 200
LOW 5
HIGH 4
PAUSE 200
LOW 4
time = 0
DO
HIGH 3
PAUSE 5
RCTIME 3, 1, time
DO WHILE time = 0
RCTIME 3,1, time
LOOP
DEBUG CRSRY, 1
DEBUG CR
' Light up LED bar topressure level
IF time > offset THEN time = offset
IF time > (offset - (MV*1)/(Mx*12)) THEN HIGH 4 ELSE LOW 4
IF time =< (offset - (MV*2)/(Mx*12)) THEN HIGH 5 ELSE LOW 5
IF time =< (offset - (MV*3)/(Mx*12)) THEN HIGH 6 LOW 6
IF time =< (offset - (MV*4)/(Mx*12)) THEN HIGH 7 ELSE LOW 7
IF time =< (offset - (MV*5)/(Mx*12)) THEN HIGH 8 ELSE LOW 8
IF time =< (offset - (MV*6)/(Mx*12)) THEN HIGH 9 ELSE LOW 9
IF time =< (offset - (MV*7)/(Mx*12)) THEN HIGH 10 ELSE LOW 10
IF time =< (offset - (MV*8)/(Mx*12)) THEN HIGH 11 ELSE LOW 11
IF time =< (offset - (MV*9)/(Mx*12)) THEN HIGH 12 ELSE LOW 12
IF time =< (offset - (MV*10)/(Mx*12)) THEN HIGH 13 ELSE LOW 13
IF time =< (offset - (MV*11)/(Mx*12)) THEN HIGH 14 ELSE LOW 14
IF time =< (offset - MV) THEN HIGH 15 ELSE LOW 15
LOOP
END]
See?
' -----[ Initialization ]-------------------------------------------------- Reset: HIGH TX ' setup serial output pin PAUSE 100 ' allow LCD to initialize DnLoad_Custom_Chars: FOR idx1 = 0 TO 35 ' download 4 characters READ CC0 + idx1, char ' get data from table SEROUT TX, LcdBaud, [char] ' send to LCD NEXT ' -----[ Program Code ]---------------------------------------------------- ' Clear the display and remove cursor and blinking attributes. Main: SEROUT TX, LcdBaud, [LcdBLoff, LcdOn1, LcdCls] PAUSE 250 SEROUT TX, LcdBaud, ["THE BASIC STAMP"] ' Scroll "chomper" animation across LCD line 2 Animation: FOR idx1 = 0 TO 15 ' scroll across line READ (Msg2 + idx1), newChar ' read new character FOR idx2 = 0 TO 4 ' animate a current position LOOKUP idx2, [0, 1, 2, 1, newChar], char SEROUT TX, LcdBaud, [(LcdLine2 + idx1), char] PAUSE 75 NEXT NEXT
Instead of like this:
[ Initialization ]
Reset:
NEXT
[ Program Code ]
Main:
PAUSE 250
Animation:
PAUSE 75
NEXT
NEXT
Of course, I would just attach the code if it is a whole program. That would be the ideal way to look at it within the editor. :nerd:
The term Mx is multiplied by 12 and was exceeding 65536. This must have caused some rollover and generated random lighting of the LEDs.
I fixed this be adjusting the circuit so that it would not go over 5000 and also testing the value just in case it did go over 5000 and limited it to 5000.
