Comparing two Si photodiode sensors with an analog comparator
tonyp12
I want to use one Red and one Blue sensor
http://www.mouser.com/ds/2/143/CLS15_22C_L213R_G_B_TR_datasheet-45815.pdf
And if red wins due to light coming in through orange tinted plastic, comparator will push or pull its output.
Slow response time is OK, Battery operated so it should use as little power as possible (maybe even polling 10x sec)
And one of these Comparators should be good start:
http://www.mouser.com/Semiconductors/Comparator-ICs/_/N-1eu2vZscv7?P=1z0y3wbZ1z0y1maZ1z0vychZ1z0vobyZ1z0vobhZ1z0vociZ1z0w4zgZ1z0voawZ1z0voaxZ1z0z7ptZ1z0x0qf&Ns=Pricing%7c0
Any recommendations on the circuit?
You will have to provide an IR-blocking filter to get the desired spectral response. But at least it will interface directly to a comparator without additional amplification.
Try this:
Back to back PV sensors are unbelievably sensitive to balanced light intensities.
Duane J
Why did I not go with Red & Green?
I then remembered an old commercial for blu-blocker, so orange should block blue and retain red
Zero is when Red = Blue current, so may not be exact equal light levels.
If you wanted more linear info, a high value feedback resistor could allow ADC on the light-change pin.
After a test with a pot I measure the settings and then use two fixed resistor values for production version.
I think this could be used as line follower, just use thin red tape/paint line.
That does not track temperature, or process variations, but you could probably get away with it as the back-back diodes will clamp at +/- 400~550mV region for lowish currents
But at $10 each (1k units) is not an option
http://www.mouser.com/ProductDetail/Texas-Instruments/LOG101AID/?qs=sGAEpiMZZMtB4tie5FrKYwbR70j%2f6jMJepY2NhN1b44%3d
The pot will set the trigger point for the Schmitt trigger I assume,
But how would I adjust so blue will win in normal florescent & daylight in case it does not?
However, since it is a Schmitt trigger there will be hysteresis which effectively reduces the sensitivity to the balance point. I would suggest using a non Schmitt trigger CMOS logic gate or a Prop input pin.
The two PV sensors, connected anti parallel, fight each other. Whichever current is greater wins and expresses its voltage.
This balanced current would cause 0V. Even slightly out of balanced current cause voltage. The voltage change is very sensitive near 0V. As the voltage rises, either polarity, the winning current is shunted by the intrinsic diode structure of the PV sensor. This causes the voltage to increase logarithmically, either way.
The PV sensors have different sensitivities to each light band so a means to adjust for this must be found.
Since the shunt diodes do consume some current there would be some point where the sensitivities would be correct.
Another method could use a second pot and high valued resistor on the other side of the sensor pair to inject current so the balance point would be at 0V. This would increase the sensitivity and not be as hindered by the logarithmic action of the diodes.
Your Blue sensor appears to be about 1/2 the sensitivity of the Red one.
Another method that could be use to adjust sensitivity is to use a mechanical shutter.
I would use this method with the Op-Amp.
BTW, I don't have this sensor myself.
Duane J
