Makefile noob — Parallax Forums
Makefile noob
OldFartRadiomanOldFartRadioman Posts: 30
edited 2013-11-12 12:21 in Propeller 1
Trying to port a library ( or at least functionality ) from PC GCC to Propgcc. The code compiles on the PC using this makefile:
mdc_test: mdc_test.c mdc_decode.o mdc_encode.o
cc -g -o mdc_test mdc_test.c mdc_decode.o mdc_encode.o
./mdc_test
mdc_decode.o: mdc_decode.c mdc_decode.h mdc_common.c
cc -c mdc_decode.c
mdc_encode.o: mdc_encode.c mdc_encode.h mdc_common.c
cc -c mdc_encode.c
clean:
rm -f mdc_decode.o mdc_encode.o mdc_test
This looks like just a straight forward multifile Make, any thoughts on how this would look for PropGCC? My last dealings with makefiles was in the heydays of the Amiga:smile: I have looked at the samples in the demo directory but quickly get lost in the maze of switches. The code will have to be highly modified to do anything useful on the Prop but I first have to get over the hurdle of getting my head around a multifile project.
    edited 2013-11-12 08:30
    Try something like this:
    CC=propeller-elf-gcc
    CFLAGS=-mcmm -Os -Wall
       $(CC) $(CFLAGS) -o mdc_test.elf mdc_test.c mdc_decode.o mdc_encode.o
       propeller-load mdc_test.elf -r -t
       $(CC) $(CFLAGS)  -c mdc_decode.c
       $(CC) $(CFLAGS)  -c mdc_encode.c
    clean:
       rm -f mdc_decode.o mdc_encode.o mdc_test.elf
    Note that the spaces at the beginnings of the lines within the rules should be actual hardware tab characters.
  • OldFartRadiomanOldFartRadioman Posts: 30
    edited 2013-11-12 11:44
    Thanks David! Compiles with just a couple of warnings. Makes me wish I had a Quickstart with me.
    Glad it worked for you!
